Well it nearly kicked my a$$ but I finally got them installed. Here's a trick, get the front end up as high as you can on jackstands, place a breaker bar with a impact socket on the nut side, place the end of the breaker bar into a pipe, now put the end of the pipe on the pad of a floor jack and slowly put pressure on the pipe/bar and after watching the pipe itself starting to flex I heard a big pop and the pipe jumped as well. Bingo, it finally broke loose.
Sure enough I crawled under and was able to then remove the nut and bolt. I needed to do the same with the other 3 but got them off. There is no doubt in my mind these things were way over the 190ft lbs the factory spec says. Especially when my impact which can go to nearly 300 couldn't touch them. They must be using Gorilla's on the assembly line installing these things, lol
Anyway, got the new LCA's install and the bolts back to the factory spec, did a quick run around the neighborhood and jumped underneath and measured the caster, Drivers side 5.9 and the passenger 6.0. I don't think you could ask for more.
After that I took it for a ride up on the interstate and ran it up to about 85, Much better, at highway speeds it centers wells and requires much less correction just to keep it straight.
All in all I would have to give this upgrade a 5 out of 5 when you factor in the cost, work and results. It is without a doubt worth the effort and time especially if your a road trip kind of person who spends a lot of time on interstates at higher speeds!
