Long LCA install
So, let me be clear on this, so if your running a completely stock non lifted 24/25 with 35's, X it may have limited value? I don't mind spending the time or money to accomplish this I just don't wish to waste my time it it has little return especially on better steering. Thanks!
You’ll have to get an opinion from someone with a 24’ or newer. Mine is a 22’ on 35’s and it made it more planted for sure. It was an easy mod with pretty good return on effort / investment for me. Should’ve come from the factory with the longer LCA’s. Hopefully someone with a 24’ or newer will chime in with their opinion.
Ours is a 24, and honestly i was shocked how perfect the steering felt to me, but as I started
With improving the suspension the stock alignment specs came to lite and it was obvious
there was room for improvement! By correcting the negative caster your toe settings become more relevant and tire wear becomes a much easier chore to keep in check, also wondering if you feel is an issue can improve drastically for some! We had no issues with our 24 it drove amazingly well but once we added those lowers that were under 90 bucks and added the bilsteins we actually felt a difference in the amount of driver input needed to just cruise down the highway, The front end just seemed more planted. We added the Clayton’s sport springs last month just to improve the handling and control the up travel or lack of!! And it’s like night and day. I was concerned with the height affecting both the caster and ability to get it in my garage as some of you know was a big challenge. Luckily, the difference in the front was minimal as I was hoping for and the rear which needed to come up gave me exactly what I needed. The castor stayed pretty much the same and once again it just drove better when you felt it was perfect before beforehand.
Longer LCAs on even a bone stock (non-X) Rubicon have a noticable impact - the stock LCAs are designed for a Sport/Sahara. The caster on my MOAB measured in the low 4s right off the truck. The LCAs were the first mod I made on my last three Rubis. If you search around on the jlwranglerforums.com you will find a WEALTH on information on this subject. Here are a few:
https://www.jlwranglerforums.com/forum/threads/mopar-lca-swap.22474/
OK I'll bite, I went and ordered them, apparently the 26 Rubicons will be coming with them standard so I guess Jeep thought the tracking and handling difference was worth the swap.
About the only thing that might be a drawback is the front pinion angle might change just a very tiny, tiny bit. But I really don't care about that because I run a FAD unit and with forced 2wd my front pinion and drive shaft does not turn anyway so no harm to foul there. $82.81 with tax included and pickup at my local Jeep dealer, it will be a good investment if it helps the tracking up on the highway which is where my 392 lives most of the time.
As long as you have your credit card out, you may want to buy one of these. You can then do before/after measurements. I measure at both the steering knuckle and the pumpkin. As I mentioned, 6° is the sweet spot. I went with adjustables because I needed an extra 1/8" to get there. [A small amount makes more of a difference than you might think]. I went from 4.5° (bone stock) to 6° (with new LCAs).
Mopar fixed-length LCAs fall about 1/8" short (which is a LOT) of getting you to 6 degrees. Adjustable LCAs are the right fix if you want to avoid loose handling or doing the install twice. People only pick the Mopars to save a few bucks, but cheaping out on suspension geometry for a $100K vehicle just doesn't make sense.
Yea this is pretty much on point if looking for six because ours topped out a 5.5* of caster with the mopar upgrade units! Although it does seem to be the perfect target approaching 6 may be on the line of possible vibration so this target would be nice but it would be on a case by case basis.
Hopefully soon I will get off my butt and install the new LCA's, as others have mentioned aftermarket one's would have been a better choice if I wanted to guarantee I hit the 6" caster mark. But in all honesty I think the 1/4 extra length should help, I did grab a digital level meter and we will see the before and after. I do have to say i'm not looking forward having to achieve that 190 ft lbs torque setting, that's gonna be a real fun for this old guy. This will be the worst part of the job for me. lol
For me this looks like the best bang for the buck especially when you consider the Performance Mopar LCA's will be stealth and never scrutinized by a dealer if I ever have a front end issue.
Have the TQ settings changed?
Well, now i'm confused, I have been told this is what the dealerships use, I do wish I had access to the factory manual set.
Lots of different TQ's out there. Mine are from the 2021 Jeep Service Manual. Maybe everything has changed. Very confusing to say the least.
I have that huge icon torque wrench and it can be done, I’m 67 and have a real bad back so I just plan ahead of time and usually figure out away to get it done!
Update on the Setup & Handling Improvements
Quick update…
I originally tried to tackle the Mopar extended LCAs myself in the garage, but doing them on floor jacks quickly turned into a nightmare with the frame bolt torque requirements and clearance. I ended up throwing in the towel and taking it to a well known reputable shop with a proper lift and air tools to get them swapped out cleanly. We followed the 140ft-lb + 145 deg torque approach instead of 190 ft-lb. Shop manager was reluctant to attempt a 190 ft-lb approach fearing snapping off bolt heads.
Once installed, the extra caster made an immediate difference—alignment check showed caster sitting right at 5.32°. Straight-line highway tracking is back, the dead-center steering feel returned, and that "wandering" sensation at speed completely disappeared.
Here is where the rest of the build stands and how it’s driving so far:
Whiteline Heavy-Duty Rear Sway Bar (Soft Setting): This was a complete night-and-day transformation. It totally eliminated the rear-end head-toss and side-to-side wobble over speed bumps. Cornering and highway off-ramps now feel flat, predictable, and planted with zero slop.
BFG KO2s (315/70 R17): Swapped over to the KO2s and noticed better ride compliance over sharp edges and speed bumps right off the bat compared to my previous Geolandars. The tread block and sidewall flex round off harsh impacts much better.
Alignment & Steering Centered: Got an alignment check after the tire swap and found my toe was off by a few minutes. Setting the toe correctly and re-centering the drag link removed the tire scrub and cleared up that last bit of sharp "thunk" over bumps.
Overall Driveability:
The Jeep feels transformed now. It tracks dead straight at speed, handles turns without the heavy V8 body rolling over, and glides over speed bumps without any secondary rear bounce. It feels tight, controlled, and much more like a high-performance SUV on the street.
What's Next:
Waiting on Clayton Off Road 392 Performance Coils to arrive in a couple of weeks to settle the front-to-back pitch and level out the stance. Will update again once those are installed!
Quick update…
What's Next:
I'm surprised the Whiteline rear bar made that much of difference considering its only 1MM larger then the factory 392 unit. Usually bigger is better (to a degree, lol)
Whiteline extends the bars length at the ears where the drop links attach. Extra length and bolt points would change the geometry and allow the bar to exert a greater amount of leverage force and perhaps this is where it makes a difference over stock.
This is great for a street machine or desert blaster but might not be optimum for rock crawlers because it would tend to hindering rear suspension movement where you want good articulation when crawling over boulders, thus the reason for the Wranglers front end stabilizer bar disconnection.
As far as the tires, BFG K02's are really great tires for giving you the best of both worlds. I have gone thru a number of sets over the years on 3 Jeeps and 3 H2's. No doubt dedicated hard core off-roaders would prefer something different with a better sidewall and more pronounced tread.
I have tried others but keep coming back to K02's, for me they just really provide the best overall bang for the buck, longevity, ride quality and low noise. They also provide good handling reasonable performance both off road and in the snow. This keeps me coming back. Jeep made a good choice here by putting these on the Rubicon from the factory.
@OldVetteGuy, have you determined your "before" caster reading yet? I'm anxious to hear your opinion on how the longer LCAs have impacted tracking. I've found this to be a surefire, inexpensive improvement that never fails to solicit, "Why doesn't Jeep do this at the factory?"
Prospective buyers attracted to the Wrangler lifestyle are often turned off by reports of flighty steering. It’s hard to understand how Jeep's product planners haven't seized on this virtually zero-cost way to capture lost market share, especially when daily driving comfort is the deciding factor for so many.
As I’m sure most of you know I also went with the whiteline bar last year, and also felt that way but it’s not just thickness that counts it’s the material used and the fact of being solid or not! I also noticed a difference! Not enough to hamper articulation but it did help in conjunction with the bilstein 8100 dsa’s so it was a win and a cheap one at that at about 175 if I remember, now with the Clayton’s sport springs it all comes together perfectly, Rides incredible and handles tight turns
Remarkably well .
Remarkably well .
Did you run the Bilstein on stock springs ?
I am pulling out my old Godzilla jack stands I use to use with my 3500 and going to do some exact measurement and place them on the 4 corners under the axle and simulating it at ride height only much higher in order for the torque wrench to do it's thing with a bar extension. At that time I will have the tires and rims off and will measure exactly what I have at the top of the spindle with the digital inclinometer before and after. This way we will have an actual benchmark before and after.
In the beginning, yes, and it was a huge difference but the shocks carried the soft OE
springs which necessitated the rear white line spray bar, once I figure out a way to fit the jeep in the garage, I moved forward with the Clayton Springs, once I install them and tuned the shocks to work with the new springs magic happened, I was now able to reduce the shock settings to almost half given me an absolutely incredible ride and still maintaining sharp handling with minimum body roll. The Jeep leveled out and I was able to use a jounce bumper from an earlier Rubicon between the springs and the shorter bumper I picked up another half inch of up travel, now this may seem minimal to some, but between the Clayton‘s and the bilsteins almost anything I did on the beach, off the beach, and looking at any speed bumps at the golf course and blasting them, i never once put the front on the stops. It was quite incredible. I am now looking at shortening those bumpers by another 3/8 of an inch the results will be coming soon.
So I have been researching and trying to get a clear answer about whether upgrading the shocks form factory to Bilstein 8100 dsa 2-3 inch shocks at a later stage without adding a lift kit that is after installing the Clayton performance springs and Metalclaok durosprings bump stops.
Would my setup work with these shocks or any other shock rated for 2-3 inch
