Long LCA install
I’m still surprised by how many members use the MOPAR kit’s LCAs to adjust caster. They’ll help, but they won’t get you to 6°.
For those looking to improve highway manners, adjustable LCAs from a quality manufacturer are worth considering. Given what we spend on our Jeeps and all the other upgrades we make, it seems like a relatively small investment for something that can make a noticeable difference in how your Jeep drives.
Honestly, if you haven’t driven a Jeep with 6° of caster on the highway, you might not realize what you’re missing. It’s one of those improvements you really appreciate once you experience it firsthand.
You got a very valid point.
What do you suggest a good pair of adjustable LCA? And is it only Lower or Upper as well?
I’ve done just lowers on my past three Wranglers. Teraflex in my case—super beefy. What surprised me early on is how a little goes a long way. You’ll only need to adjust them to no more than 1/4” longer than the fixed-length Mopars. But that 1/4” is instantly noticeable.
I think Wranglers sometimes disqualify themselves from consideration by prospective buyers because of their flighty steering. If Jeep were better attuned to this, they’d put longer LCAs on at the factory and avoid losing those sales.
One of the major reasons some go with the Mopar Performance LCA's is the fact they are genuine mopar accessory covered by your factory warranty. And if you should have an issue such as death wobble or some obscure suspension you will not run into the "You modified your suspension so its not covered".
On my 25FE I ended up with a caster a hair under 6 which made me happy and made a noticeable difference. Plus the price was right and merely a fraction of what other aftermarket LCA's cost. For me it was a win-win.
I wonder why this Mopar lCA yields varying results. For instance in my case before adding the springs, the LCA’s got the caster to 5.3 deg only!! What could be different?
I doubt Stellantis will cover a warranty claim related to a failed LCA under the original warranty. Just like they won’t cover a claim related to a mopar lift.
They may warranty the LCA under a parts warranty, but not the vehicle warranty.
I have a 25FE with is already X rated with the factory lift, you added your springs, that might be the difference.
Slightly different suspension geometry.
In fact, in a world where sometimes the motivation is to deny claims if possible, I could envision a rejected claim based on the fact that the longer MOPAR LCAs are not original equipment when matched to stock suspension. That said the longer MOPARs are certainly stealthier that aftermarket adjustibles. It would take a discerning eye to pick out the longer MOPARs from the OEM arms.
Based on numerous posts on the JL forum, it appears that the longer MOPAR lower control arms included with the lift kit work perfectly well on a stock, non-lifted Rubicon, bringing caster to approximately 6°. If that's the case, it would suggest that installing the complete MOPAR lift kit on a bone-stock Jeep would actually keep caster below the sweet spot.
According to the readings from my Discount Tire alignment, Jeep specifies a normal caster range of 4.0° to 5.8°. My MOAB rolled off the truck at 4.5°, and that's definately not optimal based on my highway driving.
Anyone who has made the switch to the longer Mopar lower front control arms on stock height 392 use new bolts for the install? Apparently many suspension related bolts are to be torqued once.
When I installed my Mopar performance LCA's I contacted both the parts department and service and was told the nut and bolts used are not (TTY) Torque to yield and do not need to be replaced.
With that said and considering they are torqued to such a high value replacing them will make removing the old ones much easier by being able to use a inductive heater on them. After that then of course you would not want to reuse them.
I swapped to the Mopars initially as a quick cheap easy fix and to match the other OEM control arms when I only had the Clayton springs installed. I had in mind I would eventually replace them all to adjustable but the Mopars did the trick until that time and made it drive much better.
iMHO if you don’t intent to go higher than leveling and don’t intend to change all of the arms the Mopars for the bill perfectly.
Just completed this change to the Mopar longer control arms. My Milwaukee mid-torque 18 volt impact spun the nuts off without problems.
As others have said here and elsewhere getting the bolt to line up on first side (drivers side first in my case) required a bit of help from a jack on the frame but was quite easy. Second arm went in without issues. That was the very easy part.
The 190 ft lbs is no joke and was a struggle on the ground. Not a lot of room for the long torque wrench to move. A friend helped and on a couple of the nuts both of us were cranking on the wrench to get it to 190.
I did notice improvement on the way home. The new ones are not even 1/4 inch longer. This pic is with the bolt through both new and old arms on the other end to see the length difference.
I bought these probably two years ago and kind of forgot about them and they got covered up by something else in the garage. Glad I got it done now.
@Viking Jeeper How much improvement though?
Hard to describe and I need some more time with it. It is possible it's the same improvement I get in acceleration after I wax the Jeep :cool:. Simple install though, until final torque.
Here's a simple test, run down the interstate at 70mph or so, change lanes and watch how nice it settles in going straight again without any extra correction going straight. I noticed the difference immediately!
Best return on money I have spent so far on the Jeep! IMO
Quick tip for anyone trying this: make sure to measure your caster before and after. A cheap $20 digital angle finder off Amazon does the job just fine. Honestly, hitting that target 6° is pretty tough without adjustable LCAs.
@Viking Jeeper - If the steering improvement isn't immediately obvious, your LCAs are definitely too short.
At the risk of sounding like a broken record—and with all respect to those running the 24.25" Mopar arms—I want to share the best advice possible, just as so many here have done for me.
Longer lower control arms definitely improve steering performance; I’ve never heard anyone who made the swap regret it. But you really have two choices: spend $50 to noticeably improve your steering, or spend around $400 for high-quality adjustable LCAs to completely transform it. Regardless of your choice, I echo what @OldVetteGuy said, it's the best mod you will ever make.
Given what we’ve all invested in our 392s, it doesn't make sense to cut corners on your steering. If you aren't cheaping out on the rest of your build, don't start here.
I would suggest that anyone with stock suspension that has no aspirations of adding a lift kit go with the Mopar LCA's and pocket the difference.
If your thinking your going to install a lift kit, change springs or other serious suspension modification go with the adjustable aftermarket ones you will be much happier because an alignment shop will be able to dial in the settings better to meet your needs.
