Long LCA install
Before I bought my ‘26 Moab I test drove a ‘23 Rubicon 392 that appeared to have a slight lift, 37”, and Core4x4 LCAs. I don’t know if they were Cruise, Camp, or Crawl versions. That Jeep drove exceptionally well. I was not sure why it drove so well at the time, but it was in a whole different league than the ‘23 Sahara 4xe I had at the time. Looking back, I’ll bet most of it was due to the LCAs. Fast forward to my current Moab, and it does drive better than my old 4xe, but not like that Rubicon.
Do you think the Core4x4 LCAs are that much better than the Mopar LCAs? The Core4x4 have an adjustment at one end.
I am leaning towards the Camp version, at $350 for the front set. Cruise is $100 less and Crawl is $100 more. Camp have a Johnny Joint at one end and a Poly Bushing at the other.
I get that the Mopar are $50, but buy once cry once.
Thoughts?
Bottom line is what do you expect to do with it, are you lifting? On road, off road, rocks, desert, mall crawler or what.
For me my 25FE is considered a road warrior, it will never see Moab or the Rubicon trail, it will visit lowes or Home depot and might hit the sands of White Sands in NM but that's it. And if Jeep ever releases a a real desert rated Mojave Wrangler with a 392 I will be first in line, this is just what I enjoy.
My priorities are good tracking, higher speed interstate driving and road trip and the best handling and longevity I can achieve.
So for me the Mopar Performance LCA's are the best bang for the buck and did a great job for me. Anything else for me would be a waste of money. I would have gone with another LCA option if I was planning on going to larger tires and a lift.
I have had a 15 Sahara, a 18 JLUR and now the 25FE with performance LCA's and so far it easily outperforms the others. I am sure Jeep engineers took all of this into consideration when creating the performance LCA's and as I have been told by my local Jeep dealer listed as the part # for 2026 Rubicon Wrangler/Gladiator so it appears Jeep has seen the advantages of these arms.
Thoughts?
Here are photos of the test drive ride. The dealer did not want to negotiate and it ended up wholesaled off to Atlanta from Austin. It started life in central Louisiana.
I've run these on my last two JLs: https://teraflex.com/jl-jt-alpine-short-control-arm-kit-front-lower-0-4-5-lift.html
My plans are a medium trail capable rig. 37s are probably the largest I would run. It still needs to be daily driver capable (one to two days a week). I doubt this will ever be a true hard core rock crawler, I can build one of those from a scrambler project. In the end it won’t be a mall crawler but it won’t be a dedicated trail rig. Something in the middle.
So the the 2026 Moabs came with the shorter control arms or longer?
As I understand it from the parts consultant at my dealership the Rubicon series of the Wrangler and Gladiator have the longer arms in 2026 depending on the build date. You can easily check this on your Wrangler: look on the inside of the arms near the rear if you see part no: 68322798AA anything else and you have the standard length LCA.
New you could do it!!! And you got to 6* lucky man! No vibrations? If not Beautiful! Do you have of pics of your jeep showing your actual stock height? I couldn’t get more than 5.5 but my 392 always sat high from the factory, just curious.
Here you go, after installation, I had measured both front and rear wheel wells were exactly 41" from the ground and they still are.
Here's some pics:
My valentine day build has the shorter ones.
68524199AB 61177 3145 a
My July build has the shorter ones also.Looking at it,it looks like you do not need to remove the crash guards to get the lower control arms out.My tools fit in there and the bolt is 4.5 inches with over 5.5 inches of room to remove the rear bolt.I may do this sooner than later:)
Couple of points, the parts depart specialist specifically said only the Rubicon models of the 26 and newer Wrangler and Gladiator would have the longer arms and that would be based on production dates. So If you don't have a Rubicon, don't waste your time looking, you don't have them.
Now with that said the replacement procedure is fairly straight forward. You do not need to remove anything but the large bolts going thru the arms and the front and rear and the bracket on the side. Look back on this thread and you can see some tricks on how to remove these nuts and bolts. I can tell you first hand they are torqued from the factory WELL over 190 ft lbs.
Also, if you do not have a torque wrench that can go up to 190 ft lbs don't waste your time trying to install them, take it to a professional shop that can remove and replace them with the wheels supported, this is important that the bolts are tightened and torqued with the suspension loaded and level.
Thoughts?
If you need more caster you will need an adjustable with will give you way more then you will most likely need! This is my current height only stock 35’s
Here's some pics:
I’m in Florida right now but I’m thinking im close to 42 with 32lbs of air, Once im back I will remeasure!
Here's some pics:
My front was very high stock my rear had that sag look!
Here's some pics:
Ya see now i remember when they claimed the FE had a little more lift well the opposite is here, I will pull up my truck before the claytons, this is why you got 6* of caster, and I had 5.5
I run 32 psi summer and 34 psi winter on my tire pressures. That gives me a great contact patch on the road.
Thoughts?
From my understanding, it’s not the quality of the LCA per se. It’s the caster angle the LCA provides.
I’m so glad I found this thread because tracking on the road was literally my only concern about buying this 392. I test drove a 2026 and tracking was my number 1 focal point. It drove ok but now that I know it can be better, I plan to make the Mopar LCA one of my first mods.
Luckily, I have access to an Auto Skills shop on post with about 20 lifts and a bunch of tools for about $6 per hour for the lift.
Will I need an alignment after installing these?
