That was the only issue? Get rid of those stock driveshafts.The failed front drive shaft, tcase end. The rubber is what smoked out and stunk.
View attachment 40146View attachment 40147
I haven't heard of anyone else reporting this type of failure. Suxs to be first, sometimes.Is that the first failure posted on this site ? Any indication what caused the failure ?
Ya, I'll get them switched in time.That was the only issue? Get rid of those stock driveshafts.
ToastedThe failed front drive shaft, tcase end. The rubber is what smoked out and stunk.
I switched to Adam's pretty quickly. I would rather deal with u-joints than CVs if I break a driveshaft on the trail.Ya, I'll get them switched in time.
Pull it and plug if needed.So I just found this! A big staple in my 38! Should I just cut it or pull it out and see what happens?View attachment 41130
Figured so much. New tire, 2500 miles.Pull it and plug if needed.
I am missing a bunch of lugs on mineFigured so much. New tire, 2500 miles.
Discount tire will usually fix it for free patch on the inside and a plug that’s the best way to goSo I just found this! A big staple in my 38! Should I just cut it or pull it out and see what happens?View attachment 41130
Love it! Links?Installed a rear glass handle and water diverting trench. Plus the rear window light bar. I installed it on the cargo rack instead of the glass.
View attachment 41358View attachment 41359View attachment 41360
Thanks looking at the light how was the wiring process looks like quite a harnessInstalled a rear glass handle and water diverting trench. Plus the rear window light bar. I installed it on the cargo rack instead of the glass.
Pretty straight forward. I cut down the leads to the light and I used vampire prongs to get power from the 12vdc socket. The yellow wire is to the dome light so the light bar turns on when doors are opened. The supplied switch has a led halo light around it so Fuse 45 is jumpered to only be powered when in acc/start.Thanks looking at the light how was the wiring process looks like quite a harness
