Small Travel Trailers
I pulled this a few times with my 2020 3.6 and it did ok. Had bags and brakes. Weighs right at 3500# loaded. Took my time though knowing it wasn't really in its element. Haven't pulled yet with my 392. Should be ample power but maybe worse pulling as it is an XR, more lift, larger tires.
I pulled this a few times with my 2020 3.6 and it did ok. Had bags and brakes. Weighs right at 3500# loaded. Took my time though knowing it wasn't really in its element. Haven't pulled yet with my 392. Should be ample power but maybe worse pulling as it is an XR, more lift, larger tires.View attachment 8058
It'll be easier to pull having an XR. More torque with 4.56 gears. I have a non XR (3.73 gears) with 35" tires and pull 3,500 - 4,000lbs trailer similar to yours. (With my larger 35" tires I should at minimum have 4.10 gears.) I do have rear airbags (and would highly suggest that to ALL who haul any significant weight with a Wrangler). I also utilize a weight distribution hitch (which makes a huge difference!!!) and of course trailer brakes.
In conjunction with the air bags, I also have my adjustable hitch set at a height to keep the trailer and Jeep perfectly level. IF Jeep comes out with a 20th Anniversary 392 (which is rumored to have 4.88 gears & 37" tires) I'm going to trade my 2021 392 in for this exact reason, to tow, as I camp regularly in the non-winter months. I will also drop down to 35" or 36" tires To Keep That Towing Torque and save my tranny. If they don't come out with a 20th, I'm going to put 4.56 gears in and keep my 35" tires. (The rumor is that in January Jeep may release a 20th, so I'm not changing anything till I know for sure.)
You, having 4.56 gears, alleviates a lot of stress on your transmission and differentials, this also keeping your tranny from shifting as much. That is, if you still have 35" tires on your XR. You will find that your XR 392 will pull your trailer with unbelievable ease. Having a weight distribution hitch will remove the pucker-factor, so, I'd highly suggest getting one.
My 2 cents...
My 2 cents...
I agree with most of your thoughts. However I disagree on the distribution hitch as the Wrangler OEM hitch is a class 2 which isn't designed for the torque loading of that type of system. The cross bar the hitch is bolted to isn't really up to the task like a class 3 hitch with its welded on side brackets which are longer and designed to spread the load to the frame. I am not an engineer but have studied trailering over the years and have seen quite a few hitch failures so I tend to err on the side of caution. A sway contrrol could be added to a weight carrying system if desired but the JL comes with trailer sway mitigation so likely not needed. Oh and my tires are still 35's and most likely will stay that size.
My 2 cents...
With respect to gear ratio you are only taking about 3500 pounds and overthinking it. I towed 8K most of the way across the country in a truck with 150 less HP/TQ and 3.23 gears. It was noticeable for sure but not a problem at all.
Perhaps I'm over thinking it. I am trying to think long term though. I'm sure I could pull even more weight than 4,000lbs, however, long term, say in 15 years, the transmission will have had less stress on it if the gears are numerically higher. It could mean the difference between a rebuilt tranny at 8 years or 18 years. Again, I am hauling twice a month, spring thru fall.
From the factory 33" tires have the 3.73 gears. The XR's 35" tires have 4.56, and IF the concept 20th Anniversary Rubicon 392 becomes reality with the 37" tires it'll have 4.88 gears. I'm assuming the engineers put some thought into this logic even if I don't totally understand why. 🤷‍♂️
Hmmmm? Good point. I wonder if I should consider welding in the crossbar.?. In all reality I'm averaging around 3,500lbs when hauling and ~350lbs of tongue weight... realizing the tongue weight becomes more when the distribution hitch is utilized.
My logic... Even if the tongue weight becomes more, say it bumps it up 100lbs, having a more stable vehicle & trailer will help keep me on the road. (I really can feel the difference in stability between a standard hitch and a distribution hitch).
Again, with all that said, I think you bring up a great point about bolts vs a weld. Do you think welding is a good option? Of course I'd leave the bolts in, but weld what I can.
Well what I see as a problem is the small contact area that the not so beefy crossmember has with the frame. If you look at a class 3 hitch even on a half ton pickup the much heavier hitch crossmember and larger/stronger contact at the frame is obvious. A class 2 hitch rating from the manufacturer isn't just rated on the hitch alone but the frame and attachment points. I wouldn't want to weld on what was designed to be a simple bolt on hitch. Could be cause for stress/cracking at the welds esp. if any of the steel is high strength. As mentioned before, I'm no engineer so I don't like to push limits or use something not as designed.
That is why it is rated as a class 2 hitch, not a class 3. Class 2 not designed for a weight distributing hitch.
Agreed and my point. I've seen (and read here) that people put WDH 's on a jeep and that's a serious strain on a weld.
I think everyone is most likely missing the point of the 'weak link' on the Jeep for towing. It's the cross member only. A 1992 Honda civic will pull 10K across the road but it's the cross member that makes our jeeps sketchy when overloading the tongue weight. HP isn't the issue. Also, by putting a WDH on the cross member, you've essentially loaded the cross member up significantly (as it's the fulcrum point). Running down the road and the welds snap, well......
I firmly believe the tow rating "weak link" in Wranglers is the wheelbase. My 2006 Unlimited (two door) with inline 6 cylinder 4.0 liter engine also has a 3500 pound tow rating.
It sure doesn't help but there are a lot of vehicles out there that have that wb (118 on 4 door).
My point exactly.
Keep in mind the 60829 are for Jeep Wranglers, not the higher lifted 392. Referencing the universal chart, I initially ordered the 60920 (5" x 9"). They were too small, length & width. I then ordered the 60925 (5.5" x 9.5"). They are snug getting in there, but fit well after doing such.
I'm not sure what the min/max specs are on the 60829 but if it's not at least the 60925 / 5.5 x 9.5 you may be disappointed.
In retrospect I wish I'd of gone with the 60926 (5.5" x 10.5"). When installing, I ran the airlines coming in from the top, using the rubber spacers to keep the line from pinching. There is an access hole in the coil mount to allow the airline to come straight down through & attach to the bags.
Tip: Ensure the body is lifted all the way up when setting the bags. Set the bags as high up as you can then add air ~20lbs. Give the bags time to 'mold' to the springs, to push through and form in between the coils in the upper position. (The expansion in between the coils is what gives its lift, not the top & bottom push of the bags.) Wait a few hours then lower the vehicle. Release the air pressure down to 10psi and you'll be good. Also, protect the bag from your exhaust pipe!!!
Found your post after searching everywhere for information about which kit to get. Thank you so much for the detailed write up. I have a XR but I don't think it matters since there's no difference in lift? I've ordered the 60926. Fingers crossed that it fits!
Good Day :)
They'll fit. Just be sure to leave some extra airline so you can get your fingers & needle nose plyers up above the bag and attach the hose clamp. You can pull the hose back a bit after it's connected, and zip tie the hose line leaving some slack for a little movement. Keep the bag collapsed as much as possible to get it up as high in the spring as possible. Zip ties can help with that, keeping the bags compressed. Once you add air to the bags and then release the air they'll stay in place, this when the jeep is raised off the ground. If you drive around with no air (or very little) the bags could slide up and down a little. Of course, you're installing the longer bags, my 'in retrospect' bags, so, sliding may be a non-factor for you. My point, if you need to make any adjustments after you take a test drive, I'd suggest spraying the bags with soapy water to help them slide up further. In reality, spraying some soapy water on the bags prior cutting the zip ties will help the bags slide into position. You may need to add air then release some air to get the bags to become cylindrical, as an area on the bag may want to fold inward.
Another little tip. Apply a small amount of silicon to the air intake nipples, be sure you don't get any in the hole. This will help the hose slide on, it is a hard fitment with the little working room you'll have. In lieu of silicone, you could put a little dish detergent in the hose. IF you notice any leaking after the hose & clamp are connected don't fret too soon. The hose is relatively hard, and the clamp is not real strong. Give it a little time, perhaps drive the jeep to warm things up down there, the hose and clamp may simply need a little time to mold as well. (That happened to me. I had everything connected and I was getting a small leak at the nipples. I was dropping a pound of air about every 10 minutes. I just left it and the next day everything molded together. No issues to this day.)
Good Day :)
Great tips! Will give it a try in the next weekend or 2 and report back with the results. One additional question if you don't mind. Have you taken your 392 off-road with the trailer attached and the bags installed? Just wondering what your experience was in terms of their durability and off-road comfort.
Yes, I have gone off road with the trailer & bags. It was not serious off road though; my trailer is not designed for trails with hills/mounds (the rear end of the trailer would bottom out), nor would I feel comfortable with the street tires as a rock could puncture them. However, if I had an off-road trailer, I would feel perfectly comfortable with the bags and would not haul anything over 100lbs tongue weight without them. (Wish I had an off the grid trail camper!) The bags are durable, just do not over inflate them keeping in mind that heat will add additional psi while also softening the bags. So, protect the bag closest to the exhaust pipe! I never go over 30psi, nor have I ever had to. Hauling 4,000 lbs. I'm usually around 24 psi.
The bags help so much! Even with nothing on the hitch I leave about 8psi in the bags. That gives the Jeep a slightly raked stance. I don't like the appearance that the front end appears/is a bit higher than the rear. It is a 'muscle' Jeep. :cool:
Your setup looks so clean! Love the exhaust wrap. Good advice on the pressure. I plan to take my Jeep and trailer into the mountains out west so I will need to take into account air pressure too. My trailer is only 2500lbs but I have over 300 lbs of tongue weight so I'll definitely put the bags to good use! I also agree with you that the droopy butt look is not for me. :)
My 2 cents...
What part # bags do you have or what would you recommend now that you have had some time? I have added so much weight to the back of the 392 with tire carrier, cargo shelf, fridge slide etc, that I am looking at some bags because once I weigh it down with gear it will be too low.
Good Day Viking Jeeper,
From previous post #46... "In retrospect I wish I'd of gone with the 60926 (5.5" x 10.5")". I currently have 5.5" X 9.5". Wish they were a hair bit longer, but the size I have works very well.
Here's a video on the subject of airbags vs WDH....
