Small Travel Trailers
I pulled the trigger on a RedArc Tow Pro Elite along with a Tekonsha Custom Wiring Adapt Trailer Brake Controllers-jeep and a Redarc Wiring Adapter For Tekonsha Brake Controller Harness all from E-Trailers.com.
Okay, so I got the Redarc setup. Problem is that there is no space in the dash to drill into to install the control knob. The 12volt outlet in the dash could probably be removed and the control knob installed in it’s place but not sure about how close of a fit it would have been between the control diameter and the exsisting hole diameter. Opted to order the Mopar brake controller that is designed to replace the outlet and function the same as the Redarch. SKU for the kit is 82215652AB and paid $278.01 which included shipping & AZ Tax from MoparOnlineParts.com. The dealership quoted me $400.00 for the same product pre-tax. Though the description on the site says that the product is on back order with no get-well date I was notified that my order shipped the next day and was delivered 6 days later.
You will be fine unless the trailer with motorcycle exceeds 3500 lbs. I’m wondering if the tow package includes a circuit in the wiring harness to accommodate a trailer brake controller in the driver’s compartment area. 🤔
Please let us know what you learn about the trailer brake circuitry. You have a very good question.
We plan on towing a box trailer w/ a motorcycle - or two.
We’ve towed an open trailer w/ a work bench on it.
Towed great - like it wasn’t even there.
This is the best we could find that would stay at near the 3500 lb wt limit. They don't make this exact model anymore, and I can't find a new one that ticks all these boxes with dry weight under 3000 lbs. Tongue weight was little over spec, but did not seem to matter.
Sleeps 4, murphy bed couch, dinette. Basically has everything except space to move around in. We have enjoyed it. 2013 Rubicon tows it fine as far as stability. We went with a tekonsha prodigy rf wireless controller that has worked great. Had to run a 10g wire to back and mount a 7 pin trailer plug in the aev bumper. Did not have to install brake controller in the jeep.
Having said that, on the 392 I will probably do the mopar trailer controller in the 12v socket approach that someone mentioned on here earlier. Wireless one is fine, but you have to move control module from trailer to trailer. Was not a problem because that is the only trailer we towed that had electric brakes.
Take a look at Braxton Creek Bushwacker PLus or Bushwackers. https://www.braxtoncreek.com/model/bushwhacker-plus-teardrop I just sold a 17BH to a lady who has a regular 2018 Rubi and she does great with it. That being said the easiest brake control system is the Curt Echo Wireless brake control. https://www.etrailer.com/Trailer-Brake-Controller/Curt/C51180.html
Due to limited areas to deal with other wiring we have found that the Echo is the easiest and works great with vehicles that otherwise need special wiring harnesses or having a whole rewire job just for a brake control. We have done numerous with the Echo and its simple and works.
Anyone plan on towing a small travel trailer?
My camper with my 2015 JKU. With an upgrade to the gears and a TrailDash, it was no problem. Definitely not a problem with the 392.
Prior having rear airbags installed or the electric brakes operational the Jeep's performance was a 7 out of 10 while pulling ~3,500 lbs at >65mph with approximately 350lbs of tongue weight driving on both dry & wet roads with pretty significant hills. I Was Impressed!!! I did have the camper trailers' Leveling Tow Bars on to get that 7. (The day I bought the camper trailer I had the Leveling Bars installed so I never experienced the 'feel' without them.) I never had any issues with power to include stopping power. My biggest contention or 'fear' (where I felt a little uneasy) was when cornering on the freeway at 65mph. After installing the rear airbags & electric brakes I'm at an easy 9 comfort level.
With the set up I have now I'm confident this Jeep could easily handle another 2k of weight; although I have nothing that heavy to tow.
Regarding the brake controller one may consider going completely wireless. This Curt Controller simply plugs into your Jeeps 7 pin harness and is operated via an app & Bluetooth. Too Easy.
I wouldn't depend on a phone app to help with stopping a trailer I might be towing. Should there be a panic stop situation... How confident might you be in finding the phone and applying the "Brake APP" for the trailer in time/effectively while applying the Jeep brake pedal if at all? Should I be towing a trailer the last thing I'm looking for is a cell phone to apply trailer brakes. Trailer brakes should be appropriately controlled by the towing vehicle's foot applied brake pedal through a trailer brake controlling device. Geez... who comes up with "I have a cell phone application to stop a trailer" I'm towing?
Might the same app cause a nearby trailer to apply its brakes?
Be safe please.
This completely wireless in-line Brake Controller that is set-up using an app is a little more sophisticated than perhaps you're giving it credit for. I have this controller and I do not have to have the app on and phone readily available while towing, tucked in your pocket and turned off it'll still work. You use the app for initial set up. You do however have the ability, if you'd like, to see the dynamics of what the brakes are doing while viewing the app in real time. Put your phone on your dash mount to see live feedback while driving, but again, not necessary :).
Side Note: If viewing the phone app while driving you can hit the 'panic' brake button if you'd like. With your phone turned off you can achieve the same, turn your hazard lights on and the trailer brakes will activate all the same. And no, nearby trailers using the same app will not tap into your wireless signal feed, it's all passcode protected. Curt engineers put a little thought into this :)
Be safe please.
The Curt Echo works perfect and we sell them were I work. The App does not causes the trailer to stop, its just used to adjust the camper brakes as well activate the Brake controller. If yur phone loses power the brake controller keeps working. Used one on my Gladiator a many of times and no problems.
Forest River has a line called R-Pod. Pretty popular in Oregon. The newest looks to be around 2714#.
The R-POD will be to heavy for a Jeep. The brochure says 330lbs of tongue weight and that measurement is without a battery or propane in the tank/tanks. 4dr JL's are only rated for 350lb of tongue weight. So even if you don't put a battery and propane in the tank you could pull it but you would basically not be able to put anything in the camper.
Look at the hitch weight. Its 390lbs and a 4dr JL jeep is only rated for 350lbs of tongue weight.
I put a 3000 watt honda inverter generator on the back and that lightened the tongue some. I figured the tongue weight was close enough. I know not in spec, but not like it is twice the rated capacity. I'm sure I'm over 3500 lbs with generator and water too, but towed fine. Prodigy brake controller worked well. Never had problems with braking or trailer sway ( had sway control on the trailer). Jeep is just a turd with the setup. Can cruise flat at 70, but struggles going up hills. Forget overdrive. Lots of time in 3rd and 4th gears. 9-10 mpg. Will run hot if pulling hard up hills (like switchbacks on a mountain)
Ideal? No, but the extra space and amenities in the camper are nice.
I tow a 2016 Lance 1575 travel trailer, dry weight is 2700 pounds. The 392 can tow it no problem, but the suspension in the back isn't stiff enough in my opinion. It sags about an inch and half, and because I have 37s it's not enough clearance to safely tow. I'd rub like crazy every time I hit a bump.
I towed the same trailer fine with my last Rubicon, but I had upgraded the lift/suspension. My 392 lift and suspension are currently stock, so waiting to tow until I get that figured out. I'm upgrading the axles and going with coilovers, so it'll be tricky to make those work and also have it tow well. We'll see if I can get a setup working that is safe, otherwise I'll have to stick with only towing my trailer with my daily driver :/
edit: I have the mopar brake controller on order, but it's been a few months. The one that replaces the cigarette adapter spot.
I tow a 2021 Airstream Basecamp 16Xwith my 392. It weights 2,700 lbs & has a tongue weight of 450 lbs. I have a Centerline weight distribution hitch that all but corrects what you're describing. I towed the Basecamp to Moab & back with absolutely no issues. In fact, I could barely feel it back there.
I also use a weight distribution hitch, but didn't make enough of a difference. Still waiting on my suspension upgrade, and same for the brake controller. Hopefully soon, I'm looking forward to using my RV soon in the Spring.
I'm considering this one. Very light, but also compact. Not a lot of space for gear and such. The price goes up quickly with options. I have not made my mind up on which trailer, but I know I want to get one in the next year or so. https://www.tentrax.com/ascend
Maybe check out Mammoth Overland trailers.
