Anyone plan on towing a small travel trailer?
You will be fine unless the trailer with motorcycle exceeds 3500 lbs. I’m wondering if the tow package includes a circuit in the wiring harness to accommodate a trailer brake controller in the driver’s compartment area.Yes, we are planning on towing the motorcycle trailer.. “they say” it’ll be fine.
Yes, we were wondering the same thing. Our son just bought a trailer and there is an APP on his phone he uses for braking. We need to talk to him about that and see how that works?You will be fine unless the trailer with motorcycle exceeds 3500 lbs. I’m wondering if the tow package includes a circuit in the wiring harness to accommodate a trailer brake controller in the driver’s compartment area.![]()
If it is like my 19 rubicon (ordered with tow package), It will have a connector under the drivers side dash for the trailer brake and charge circuit. You can get a mating connector from the trailer brake vendors and make a short adapter harness to plug into the jeep and trailer brake controller.You will be fine unless the trailer with motorcycle exceeds 3500 lbs. I’m wondering if the tow package includes a circuit in the wiring harness to accommodate a trailer brake controller in the driver’s compartment area.![]()
Thank you Beckbuilt! Good to learn that that there should also be a charging circuit available as well, my trailer needs that to charge its battery. I have experienced very good service and performance with several Prodigy Brake controllers in various vehicles over the years and will most likely go with another one of their products.If it is like my 19 rubicon (ordered with tow package), It will have a connector under the drivers side dash for the trailer brake and charge circuit. You can get a mating connector from the trailer brake vendors and make a short adapter harness to plug into the jeep and trailer brake controller.
Check out the Red-Arc controllers. They have a wired remote allowing the base to be mounted out of view. They’re great for vehicles with limited dash space.Thank you Beckbuilt! Good to learn that that there should also be a charging circuit available as well, my trailer needs that to charge its battery. I have experienced very good service and performance with several Prodigy Brake controllers in various vehicles over the years and will most likely go with another one of their products.
Thanks Again! I'll check out the Red-Arc line.Check out the Red-Arc controllers. They have a wired remote allowing the base to be mounted out of view. They’re great for vehicles with limited dash space.
I pulled the trigger on a RedArc Tow Pro Elite along with a Tekonsha Custom Wiring Adapt Trailer Brake Controllers-jeep and a Redarc Wiring Adapter For Tekonsha Brake Controller Harness all from E-Trailers.com.Check out the Red-Arc controllers. They have a wired remote allowing the base to be mounted out of view. They’re great for vehicles with limited dash space.
One of the reasons I wanted the 392 was to make towing easier. I had towed with my 2019 JL 6 cylinder a little and it did better than I expected in some situations but I always wondered how the 6 cyl would do on a long trip towing a trailer. That is considering my previous Jeep struggled to go over 70 mph. (on 37's and lifted).Anyone plan on towing a small travel trailer?
FABULOUS… we’ll be towing a trailer … great to know. TY (jeep looks A MAZING)… cannot wait. - mines on the train….One of the reasons I wanted the 392 was to make towing easier. I had towed with my 2019 JL 6 cylinder a little and it did better than I expected in some situations but I always wondered how the 6 cyl would do on a long trip towing a trailer. That is considering my previous Jeep struggled to go over 70 mph. (on 37's and lifted).
So when I had to haul this very heavy log over an hour way yesterday I was curious how the 392 would handle it.
In short, I'm not even sure the 392 knew the trailer and 3500lb log was back there. (surely it wasn't over 3500lbs as that is the towing limit)
It literally pulled it without issue. I had to ease off the acceleratorView attachment 427View attachment 428View attachment 429 several times as I got up over 70mph and was barely working the 392.
After pulling the heavy log and trailer to the sawmill, I had recorded an impressive 14.9 MPG. I don't even get that driving around town. (my foot is heavy and the motor sounds cool)
So pulling a travel trailer is going to be no big deal whatsoever. This log was a beast. White oak, right at 16 feet long along with a 'crotch' piece.
After taking the log off, I'm not kidding, I could barely tell I was towing a trailer.
This trailer would be an amazing comfortable off grid experience. Very fancy.I was wondering how the 392 would do paired with one of the Black Series Trailers such as the classic 12. It's right at 3300 pounds. - https://www.blackseriescamper.com/travel-trailers/classic12.html
Congrats on your 392 almost arriving.FABULOUS… we’ll be towing a trailer … great to know. TY (jeep looks A MAZING)… cannot wait. - mines on the train….
OH, what cha doing w/ that IMPRESSIVE Log??
