Small Travel Trailers
Anyone towing a trailing have the issue of your headlights pointing too high? I just took a trip down the coast (West coast) and when I am pulling the trailer, I kept getting flashed like my high beams were on. I disconnect and no issues.
When I towed this trailer behind my 2012 JK, never an issue and that was on stock suspension. Thoughts? Or do I need to adjust my headlights for each trip if going at night? I also saw that @justinB added airbags. Would that solve it? Thx!
Airbags, weight distributing hitch or adjust headlights. I adjusted headlights on my 2013 jkur. Yet to toe with 392
Thanks....I've tried two out of those three before. So maybe I will look into trying the airbags this time around.
I was wondering how the 392 would do paired with one of the Black Series Trailers such as the classic 12. It's right at 3300 pounds. - https://www.blackseriescamper.com/travel-trailers/classic12.html
Do some research before buying a black series. Two dealers here in Colorado stopped carrying them due to the challenge of getting warranty items covered by the manufacturer. Both dealers also shared they were the worst units as they had to hire more techs just to service the high number of repairs on black series. 🤷🏻‍♂️
Just bought these...https://www.airliftcompany.com/shop/60829/. Should get them in the next couple of days and install them myself. I'll post-up a review afterwards.
Keep in mind the 60829 are for Jeep Wranglers, not the higher lifted 392. Referencing the universal chart, I initially ordered the 60920 (5" x 9"). They were too small, length & width. I then ordered the 60925 (5.5" x 9.5"). They are snug getting in there, but fit well after doing such.
I'm not sure what the min/max specs are on the 60829 but if it's not at least the 60925 / 5.5 x 9.5 you may be disappointed.
In retrospect I wish I'd of gone with the 60926 (5.5" x 10.5"). When installing, I ran the airlines coming in from the top, using the rubber spacers to keep the line from pinching. There is an access hole in the coil mount to allow the airline to come straight down through & attach to the bags.
Tip: Ensure the body is lifted all the way up when setting the bags. Set the bags as high up as you can then add air ~20lbs. Give the bags time to 'mold' to the springs, to push through and form in between the coils in the upper position. (The expansion in between the coils is what gives its lift, not the top & bottom push of the bags.) Wait a few hours then lower the vehicle. Release the air pressure down to 10psi and you'll be good. Also, protect the bag from your exhaust pipe!!!
This is excellent information @justinB!! Thanks! Just amended my order to the 60926's.
What brand trailer is this?
The company used to be known as Adventure Trailers out of Prescott Arizona and they used to make three models of trailers. The one pictured is called the 'Chaser', which the the smallest one they made. Adventure Trailers has since changed the company's name to AT Overland Equipment and now specialize in equipping trucks as overlanding vehicles and still in Prescott. Though they don't advertise them, however, I suspect that they may still have the capability to build the trailers or may know of some used ones that might be for sale. Here is their website https://atoverland.com.
Wondering if anyone is worried about the actual 'cross member' and not a frame mounted hitch being the weak point. Using a distribution hitch theoretically only puts more pressure on the crossbar? Overloading it, well......speaks for itself. The welded crossbar is my concern going over the 350lb limit (understanding that, "yes in Europe or AUS" comments but doesn't solve the U.S. insurance dilema...ha). Welded vs frame mount seems to be the weakest link.
HHMMM.... very good question, Looking forward to member inputs as I am not an engineer.
I do as well. It's something that I think most 'don't' think about. A lot of talk about WDH's but that only makes it worse (imo) on the cross member.
I tow the Road King on a UT10 ALUMA that’s got a 10’x6’ rectangle main area. Trailer, Bike and Gear we are about 1700-1900 lbs. Towed from Fort Collins to Grand Junction this Summer up and over Vail pass on I70. Performance change was hardly noticeable. As expected gear trans up shift was slightly delayed on inclines, temp was maybe 2-4 degrees warmer on steep inclines, braking and handling had no noticeable change.
And when you’re going up hill and want to pass, it will still roar from 50-90 in a few heartbeats and put that smile back on your face where it belongs.
That is why it is rated as a class 2 hitch, not a class 3. Class 2 not designed for a weight distributing hitch.
