@WhiteBronze392
@tropicthunder392
Mine won’t let me do anything nowHave you guys having problems tried going back to the previous stable version?
You can't update to the latest beta file?Mine won’t let me do anything now
Nope it doesn’t read the NoLimitzYou can't update to the latest beta file?
Try stomping on itNope it doesn’t read the NoLimitz
I unplugged everything and put it back like it wasQuestion to those who are removing their NLimitz devices when having problems, are you simply unplugging the 6 pin connector and removing the module or do you have to restore everything to be able to use your Jeep?
Since the connections are CANBus, I would imagine the most efficient method would be to just unplug the module and leave the rest of the wiring in place.Question to those who are removing their NLimitz devices when having problems, are you simply unplugging the 6 pin connector and removing the module or do you have to restore everything to be able to use your Jeep?
When I just unplugged the NoLimitz module on mine it still wouldn’t start. That’s why I unplugged everything .I would think ZAutomotive would be keeping an eye on the forum, It would be a nice thing to know for sure if you can just get away with unplugging the 6 pin connector from the NoLimitz module or if you in fact need to tear the dash apart again just to disconnect it.
On the 23 and earlier its not a big deal but the 23/24 its a pain, the leather dash topper is a bit fragile and easily damaged.
Yea it’s super quick on my 23 popping off the HVAC panel. But I think it it answered my own question of if someone was trying to steal it removing the glove box to get to the canbus seems to be standard (from pics I’ve seen) if a thief saw and just unplugged the NoLimitz to get by it but looks like they’d have to take the time to do some more replugging lol.Thanks for the WriteBronze, I think we need ZAutomotive input here, if the NoLimitz can cause a failure that prevents the Jeep from running ZAutomotive needs to come up with an optional bypass plug (if it's even possible) this is something I would immediately buy one for my Jeep's emergency kit. I am hoping they can chime in here!
Just tested it. Worked perfectlyTen4Jeep, good detective work, So with the NLimitZ unplugged the intercepted CANBus signal no longer makes it back because NLimitz is unplugged so the Jeep wont run.
Again, if my thinking is correct a simple female jumper plug that you could plug in would reconnect the intercepted CANBus signal back and all would be ok. This would also be good if your going to the dealership and you want to remove the module before service.
For what its worth I know first hand on the early JL's Stellantis had some real issues with those CANBus connectors in the glove box, my 2018 spend some time in the shop for this. I would not want to have to do alot of plugging/unplugging on that strip, perhaps it's no longer an issue but still for me it's a consideration.
Ten4, looking forward to your next post! I think I might just see if there is a female connector that might be available to use as a NLimitz bypass plug in case it needs to be removed.
Probably never. They are making a lot of changes. That means there will be more beta versions in the near future. Why don't you just install the NoLimitZ with the original (stable) version? It disables the MDS just fine.For you NoLimitz Beta testers, can anyone elaborate on when the 24.1.6 might come out of beta, waiting on the update before installing the new NoLimitz module.
Considering some of the issues others are having on the Beta I think I will wait a bit longer.
can't wait to get rid of that MDS crap though and looking forward to the new access system.
They make it much harder than it really is. When you get the message that the program cannot find the Serial Port just click 'OK' (don't make any changes). It will take you where you need to be. No need to go into Windows Device Manger.Next then plug in the NoLimitz, the red led should flash momentarily on the device and you will see a device indicated as "USB-SERIAL CH430. In the windows Device manger menu under ports. If the device led does not briefly flash when plugged in likely your hardware is bad. Start the programmer, select NoLimitz from the menu, enter the com value in the Device Discovery menu associated with the device and click ok.
