@WhiteBronze392
@tropicthunder392
Featured
- Thread starter
- #421
Absolutely please share pics doubt I will move the head unit but still deciding on the mic location.The MTX275 is so nice and easy to install, and mounting the main unit is not hard at all due to its smaller size.
Looks good @WhiteBronze392! I mounted mine on the driver's side, up under the knee bolster. There is a nice little platform/module there that I attached the mounting bracket using 3M VHB tape. For the mic cable, I cut in an RJ45 connector on the passenger side of the center console, near the front mounting bolt. I'm using a CMM accessory bracket and 67D arm with a Magnetic Mic attachment to hold the handset.
If you want pictures, I can share. Just tossing out some other ideas for those who haven't tackled the install yet.
Edit I have this PENGLIN 2Pack RJ45 Shielded Panel Mount Coupler, Ethernet LAN Pass Through Connector, CAT6A Female to Female Bulkhead Extension Interface Adapter https://www.amazon.com/dp/B09WM84YRF?tag=jeep392-20 that I saw on @7.62x392 post if I recall just trying to determine if and if so where I want to put it. I installed the extension cable that came with the unit today and zip tied it over in the corner under the glove box
