Been a busy weekend clearing boxes out of my garage!
Yesterday I got the Rock Slide Engineering step sliders and armor installed, and the light kit for them too. I have the door delete kit to add, and will probably do that when I install the Kraken/ARB compressor. I’m happy to report there were NO issues at all with the body bolts! 🙌
Today, I got the Teraflex Alpha hinge system and Alpha tire carrier installed. I set the tire carrier for my 37 Ridge Grappler / Method 703 backspacing combo, so I figured I might as well swap all the wheels too. The Teraflex parts are beefy and solid.
I’m loving this thing and can’t wait to get the Clayton suspension installed soon. And the winch…. and the lights, and the list goes on!
I’m really anxious for the replacement hood decals and vent decals from Pixel Decals to get here. Not sure when that will actually be though.
Looking awesome man!
Since they are arriving at dealerships and a few members have already taken delivery. Tell us about your modifications, upgrades, repairs and customizations!
Can't wait to try them out. Easy install but needed 1 1/2" spacers to get them to work with my non-XR wheels. Still a tight fit.
Looks good!
How do you feel about the height of the lower step? I have a Ram with power slide steps. They're almost too low- its an awkward step "up" if that makes sense. (If you could add your height that would be helpful.) Also- is the step large enough for an actual foot? Or are you just using the ball of your foot? I've seen a lot of poor reviews on these so I am really hesitant; but this isn't my rock crawler and I need people to be able to get in an out. (It's weird. I can't imagine why no one wanted to climb into the back seat on my 2 door with a 4" lift. Everyone wants to ride in this Jeep.)
Looks good!
I know the RSE steps aren't hardcore sliders when compared to some other options, but they are solid. Install isn't hard either. As long as you don't hit the body bolts with an impact, I think you'll be just fine. I used an 18" breaker bar, and did 1/4-1/2 turn, before reversing 1/8-1/4 turn. This really helped things to go smoothly.
When we climb into the Jeep, we don't step onto them square, but at an angle. So, they're certainly not wide enough for a full foot length, but they feel like a normal step to me. They'd also be adequate to stand on if you had roof-mounted accessories. I'm 5'10" and my wife is 5'2". The RSE steps will definitely keep us from sliding in/out of the seats and damaging the outside seat bolsters.
Some measurements for reference:
The step portion is ~2.75" wide, and ~49" long.
My Jeep is a 2023 392XR, with 37" Nitto Ridge Grappliers (approximately 36.77" according to Nitto).
The top of the step is 14.75" when it drops down. For us, this will go up just a little when I get around to installing the Clayton 2.5" Overland lift.
Also, RSE updated their wiring harness for these steps. There is now a master kill switch that mounts under the hood right next to the battery. This will kill all power to the steps. In addition, there is the 'sleep' switch which mounts by the OBD-II port and that is used to disable the steps while off-roading, washing, etc. If you're Jeep isn't going to be driven for several days/weeks, it's recommended to turn the steps off at the master kill switch to eliminate any parasitic power draws.
My Jeep is a 2023 392XR, with 37" Nitro Ridge Grappliers (approximately 36.77" according to Nitto).
Thank you so much for all the details!!!! Especially on the master switch. I hadn't considered that - the 392 isn't my daily. I usually drive it every few days but I've got two other vehicles on trickle chargers. Worrying about a third is probably more trouble than its worth. Might just have to go the old fashioned route.
Installed Tinted Oracle Flush-Mount Tail Lights (with Threedom beveled inserts) and Oracle Cargo Light. At the recommendation of Oracle rep and various other forum posts I used some 3mm foam tape to adjust the aim of the BSM sensors downward and outward as much as the housing would allow. Will see how it performs once I get it out on the road but I’m sure I’ll lose some degree of BSM functionality. That said, I don’t care. . . these things look freaking awesome on The Beast!!! Plus the obvious off-road clearance improvement without the ginormous bulky OEM tail lights with XR extensions. Really, really happy with them. Here are some pics starting with a side-by-side with one Oracle light installed and one OEM for comparison. I already had the Oracle bumper-mount reverse lights, which now coupled with the reverse lights in these new lights is near blinding, even in daylight. The cargo light replaces the OEM rear wiper assembly cover and provides great lighting into cargo area and down below rear window (two separately aimed LED strips). Also has a third flashing amber hazard light. Simple plug into rear cargo outlet for power.
Added Hothead Headliners, a Rugged Ridge interior storage box (and covered the exposed rear with stereo felt), a storage rack, and put in some fender gap seals.
View attachment 22684View attachment 22685
I've never seen those drawers before but they look nice. Can they be separated? I think just one would work for me. Can you provide dimensions? Obviously I can see they fit and are made for JLU but I am thinking of them for my 2006 LJ.
So Monday i am taking my Jeep to Utah to spend a week with
The Jeep Guy. you might ask why. let me tell you. so when i purchased
my Evo 4.5 inch Coil over kit i figured for this kind of money well it should be
dialed in. well its not. on the road its amazing but on the dirt roads and really
getting after it not so much. Evo would not even consider letting me bring the
jeep to him. Not allowed. So the Jeep Guy really answered a lot of questions. wanted to see pictures of the jeep and how much it weighed and spring rates on all 6 springs. seems they all come with a generic spring. not that its bad but not
for a 6130 lbs jeep loaded with gear and people. so its going to be fine tuned to the very best of its ability. i am expecting to be very pleased. Zack seems super
nice and by his YouTube channel looks like he knows what he is doing. looking forward to getting it back dialed in.
The box fits snug in the rear, doesnt make full use of the space but does use a lot. IIIRC, Rugged Ridge has the dimensions posted on their site…but roughly I know (because I covered the rear/back with stereo felt) height is 10” and width 34”…I just dont have depth off the top of my head.
Tops arent removable, but one can be pulled forward to use as a table. And drawers can be pulled out full length/be removed as needed.
From experience, I will add the box is heavy and will arrive with some form of damage. The packaging isnt enough to protect edges and walls, mine came dented and slightly askew. Rugged Ridge did send me a replacement, and were really responsive and nice…but the replacement box wasnt in a condition worth swapping for.
And I admit to being influenced by @whitebronze392…because I picked up some Tuxmats but also added some Rugged Ridge door protectors.
LoD Signature Rocker/Rails and my Artec full bellypan arrive tomorrow and Friday…and hoping to have those installed right after the holiday. :)
That will be awesome! Sorry Haha I love the tux mats especially with two kids they clean up so easy! I am still having regrets / second thoughts about not going with Artec or similar. Maybe in the future if my factory skids start getting banged up
After some time, please report back about the known moisture issue with Oracle in-bumper backup lights.
Not everyone seems to have a problem.
I have a set, but haven't installed yet due to reported issues. I supposedly have the "new" version with bevelled edge to fit driver side?
I went with Diode Dynamics hitch mount backup light for now. Simple install.
I’ve not had any issues with moisture with the bumper reverse lights, at least not yet anyway. I did have to grind down the driver’s side light to get it to fit, bit again no issues as of yet. [Knock on wood]
I have also held off on the Oracle backup lights for a bit to see if they change design to address moisture and fit.
A friend in NJ whose rig lives outside installed a set last October. No moisture issues.
