I don’t really subscribe to this but warn Manual says replace winch line every year. I say inspect it and go from there. I keep mine out of UV as much as possible. I don’t think bleeping Jeep replaces there’s every year they use there’s often
Good call, that’s on the list once it’s installed. Deciding if I should replace with the same line or go with a badlands for half the price.
Check out bleeping Jeep recovery line
The Boys and I just started painting the 392 AEV in spring colours..... The Mountains are going spring on the South facing slopes with us.
Added the Redline Tuning QuickLIFT Elite. I have no idea why I waited so long to pull this trigger; well worth it.
Sneak Peek....
Just a couple of many changes forthcoming; just waiting on the shop time šŸ»
I got these backing plates after removing my bumper extensions. They are a very good quality part and the price is more than reasonable. I have attached pics of mine. I did not like the rubber strips supplied in the kit, so I took some self adhesive backed 1/4" neoprene strips and tried to make a gasket that would seal the gaps. My finished product isn't very good looking and I am thinking about trying again...lol. Be aware the plates are flat and not "form fitting". there are significant gaps between them and the bumper as shown in my pics, but they are more than adequate to cover up the wiring etc. Comments?
Had to decide between a $700 spare wheel and tire (which would never be used for more than a rotational spare) and $170 spare tire delete. See choice below.........
After looking at at least a dozen brands... I decided on the DV8 model. It's not intended to fit with the factory tailgate reinforcement, but worked around that as i like the reinforcement looks and didn't want to give it up. Unfortunately there is no delete kit that will work with the factory onboard air compressor.....so that got deleted. (no haters please). I talked to DV8 about something that would work and they didn't even know there was a factory air compressor option. had to send them a pic of it. another headache was the later rear factory cameras are different than early models. had to do some improvising (grinding) to make that work. It doesn't some with the nylon plastic plate mounts. I had to make those fit (more grinding). But after all the reworking......I love the look.......comments?
Well that gives you a great and clean spot to mount a roto pac fuel container .
I had my eye on the MagnaFlow Street Series for many reasons but was on the fence whether to order it. Then comes @Focker with a heads up that www.hottexhaust.com offers 20% off and free shipping ($3048.00 delivered). So I blame him! lol My impression of it is...
Sounds great!!! It has a deeper note and throttle response seems to be improved as well. In-cabin sound level is less in both modes as is MDS. The build quality is very good. I installed it myself which had its challenges at times. So, my tip is do yourself a favor and have a friend help which is guaranteed to eliminate any foul language coming from the garage. lol I'm very happy with the quality, fit/finish, its looks and it sounds very very good! (y)(y)
Sounds great!!! It has a deeper note and throttle response seems a bit better. In-cabin sound level is less in both modes as is MDS. The build quality is very good. I installed it myself which had its challenges at times. So my tip is do yourself a favor and have a friend help which is guaranteed to eliminate any foul language coming from the garage. lol I'm very happy with the quality, fit/finish, its looks and it sounds very very good! (y)(y)
How do you like your MC rear bumper?
I really like it. It's far stronger than stock as you can imagine. I chose the full width version which offers more corner protection and a place to step than the narrow version.
I really like it. It's far stronger than stock as you can imagine. I chose the full width version which offers more corner protection and a place to step than the narrow the version.
Thank-you
I am running a Metalcloak 4 1/2" lift, and yesterday I changed rear shocks from King shocks for a 3" to '5" lift to King shocks for a 6" lift. The shock body for the 6" lift shocks is 1 3/4" longer than the shock body for the 3" to 5" lift shocks, which allows another 3 1/2" of down travel. I tested the increased rear suspension articulation today. I left the front sway bar connected for this test, because I was trying to force the rear suspension to do all the flexing. With the front sway bar disconnected the front suspension still flexes more than the rear, but the rear suspension is getting to the point that I think it is "good enough". The tires haven't left the ground yet, so it might flex a bit more, but I think I'm getting pretty close to the limits of articulation of a short arm suspension, and tire clearance for 40s after trimming all of the pinch seams off. The longer shock length seems good, because at full stuff with the bump stop squashed, I have 3/4" of shock shaft still showing.
Jeep Wrangler JL What did you do TO your Jeep JL today? 392 rear flex
Jeep Wrangler JL What did you do TO your Jeep JL today? 392 rear flex 1
Jeep Wrangler JL What did you do TO your Jeep JL today? 392 rear flex 3
Jeep Wrangler JL What did you do TO your Jeep JL today? 392 rear flex 4
Sneak Peek....
My Redline Struts didn't come with the 1 tons. I even double checked the box to make sure they weren't hiding under the packing materials. I will call them tomorrow.
@ParadigmDawg - I dropped her at the shop this morning and had them double check that they didn't inadvertently send me your tons with my Redline's; they did not :LOL:
That just isn't true.
I contacted them this afternoon and they said they inadvertently sent mine to Arkansas and that the recipient refused to surrender them. They said something about an attorney being called next.
