It was done by dealer. I bought a 3-time oil change package for my previous JL MOAB and got 2 times left. It took them about 20mins
Dont forget you get 3 free oil changes with every new Jeep using the Jeep wave program.
Went topless … then went soft on the idea. ;)
Hooked my 2018 Sport soft top with no connection issues.
I was pretty concerned about getting my 35's in Load E but they ride great! Nitto Ridge Grappler.
I guess it really doesn't ride worse.. somehow just noticed tire pressure was 42.
37 KM3s fit this thing just about perfect imo. Still kind of want to go back to the stock wheels now that I know I can get a 1.5" spacer on there without trimming studs.. maybe even 1.25.
I'm wondering about spacers also but still dont know how much room there is on standard 392 wheels. If I could find XR wheels I think I would be fine with that offset.
Personally I feel on regular 392 wheels with a +44mm offset.. a 1.75" spacer would be about perfect. Put it about 0 or -2
Finished my twin ARB install. I bought this a year ago shortly after ordering the 392. I took deliver in July and finally got to it this week. It took 3 days to complete but several interruptions, work, home, and beer.
I tried to cut the minimum amount of carpet. I ran the wire bundle through the rubber grommet along the top of the frame next to the factory wiring into the engine compartment. I wrapped the harness for heat protection
. The length of the cable was almost perfect, I had to add about 9" to the ground wire.
Got my Outback Adventures tailgate table today. I have not installed it yet but this thing is VERY well designed, made, and shipped. I am slightly concerned over the weight on the tailgate, it will probably be like having a 40 inch tire rather than 35. I would have been happy with a more simplified version without magnet, cutting board etc. Not much weight saved at all but the table itself could have been more low profile also and saved cargo room. The table without the cutting board is bigger than the table I made for my TJ and I find that one very very useful.
A thorough detail
Waxed, polished, sealed, trim treatment, tire gloss.
Good till next year.
Havoc HS2 side steps, Rokblokz front mud flaps
After 4 years in a JLUR and 4 months in the 392…Yesterday I noticed a post mentioning being able to modify the speedometer screen display??
Curious I went out to the garage and started digging around. Just couldn’t find anything in my 8.4 screen settings windows relating to what I had just read about.
But then…I started playing with the steering wheel buttons to cycle through the 9 options and found that one that says setup. The one I’ve seen 100 times before, but never used. Duh!
I added miles till empty and a clock above my speedometer!
It’s the little things… 😊
Clock above the speedometer? I'll have to give it a try. I've been wondering why there's only clock on the touchscreen but couldn't figure out how to show it on behind the steering wheel.
Go to settings on your Speedo cluster using steering wheel. Can change the whole set up
