Added a Brawlee rear window light. The white seems to be a bit bluer than the older model.
Added sockets for my ARB fridge, USB A and C chargers, and a cigarette plug.
Which kit is that? Did you run new wiring or did you use the stock cigarette lighter wires?
Which part?
The Brawlee light is on a switch that I tapped into the rear power plug.
The ARB socket is their proprietary kit, comes with 20ft of 10 gauge wire.
The sockets kit I got off of Amazon. I threw away the wiring it came with, it was 16 gauge and fell apart when I took the leads off to install it. I ordered 20 feet of 10 gauge wire to use, and made new wires between the switch and two sockets on the right. I used an extra switch I had rather than use the one that came with the kit. I installed it with a 15 amp fuse. I use it to power a heated "lunch box" that I have when on the trail to heat up meals for lunch.
It is pretty sturdy, much more than I was expecting. The underneath of the console has rigid plastic that reinforces it. There isn't any deflection with I plug things in.
Do you happen to have a tailgate table or know if it’s compatible with one?
I don't. I would check via their website... I suspect it would be find, but I would definitely verify.
Which part?
Ha, I couldn't have been more unclear...
I was talking about the sockets but now I am a little confused when you mentioned the ARB socket. I don't actually see it. When I look at the ARB socket online, it looks like what I may need but I am a little confused on what cord to use going from it to my EcoFlow since it doesn't seem to be a standard Cig lighter plug.
I just ordered one of these. I plan on just using one of the aux switches unless there is a reason to run it continuously hot. At least with the Aux switch I can choose to run it off ignition switch or battery and have a little more control over it than a remote I will misplace.
The rear power plug is ignition switched unless you move the fuse to make it constant, correct?
The rear cig plug socket is a 2 position fuse so you can make it hot or ignition by moving the fuse over 1/2 slot.
jmwillia said:
Not a big fan of these rock rails, rather have side steps lets see some pics of 392s with side steps.
Took out a windshield on the Moab trip... had the Gorilla Glass installed today and will give that a shot; it's my first experience with this product.
You can at least get rock rails that look like side steps.
Macy Gray and her steps
