Dzldust
Anytime, I just installed mine recently, I worked for a Jeep shop for years and hated return visits for leaks ,squeaks and rattles so I’m super attention to detail on all my projects and hate it when despite the attention something still leaks or what not, It’s funny that I could not find a video or breakdown specific to the 392 for the install. I ran into issues with the rear bolts and the exhaust getting in the way. I had to drop the exhaust from the collector and the passenger side ,pics looks funny but everything is straight and tightened to spec, looks like I’d have clearance to tighten the rear bolts but there was no way to get a torque wrench in there with the crossover bolted inShort answer is Yes.
The longer answer is I've not been able to determine what the root cause of why the pan leaked in the first place. Always from the rear #13, 3 and 10 bolts.
The fix was ultimately a couple sets of M6 x 1.00 x 25mm and 35mm
The other step taken was the last test drive for the leak was longer in distance and duration, Not just a trip around the block.
All that said, once there were no signs of leaks, I quickly bolted up the skid plates - out sight outta mind. Maybe today I'll have a peak under there.
Thanks for the nudge @Dzldust
