PPE Aluminum transmission pan
That is going to be the wrong pan and maybe even the pan filter too unfortunately. The 850RE is the transmission for the 3.6L V6, not the 392. We have the 8HP75 transmission.
Well that’s not good, guess I’ll get on the phone to PPE and see if I can update.
So what's the right PPE part number for the 2023' 392?
I did the same research that @jeepguru posted. Definitely you want the one for the 8HP75 transmission.
These are the raw aluminum part numbers but you can easily search them on the PPE site and find the other color options too.
You just need to decided if you want a +1QT or +2QT option.
228053400 = Plus 1QT Additional over OEM
228053000 = Plus 2QT Additional over OEM.
Well I called PPE and they said that my pan does have a bit less capacity which also means that there is better bottom clearance. Extra 1 quart, and this one also has a ground away section to clear the exhaust crossover pipe. Tech said this one will work with the 875 transmission. So I guess it will be an experiment.
@redbeard719 I've got the 228053400 in stock.
According to PPE, both pans fit the 875 trans.
That's good to know. It's definitely a little confusing with all the different types of 8 speeds that Stellantis/Jeep have used, and then factor in the varying amounts of additional fluid capacities/pans from PPE, and it easy to get mixed up for sure.
I did end up with the 228053400 in raw aluminum. Mine is going to be tucked up above an Artec skid, so I didn't see any reason to splurge on appearances.
This thread should see all pan options from PPE test fitted though and hopefully help others that explore doing so. The drain plug alone make the upgraded pan worthwhile.
How have these pans been working out? Any issue with skid clearance?
It looks like there are 2 options for 392 (+1 and +2 quarts). Seems like you must use their trans filter, but they don't sell a gasket. I can see jeep sells the gasket - but if they are moving to integrated pans then don't we risk not being able to get the gasket from Jeep?
Has anyone measured the hight difference between these pans and stock?
I installed a PPE aluminum transmission pan on my 392 overall not too bad, but there are a few things to watch out for. It was a modest weekend job: drain the fluid, remove the stock pan, clean the sealing surface, install the PPE pan (with a new gasket), refill fluid.
Fit was good no clearance issues under the 392 and it seems sturdier than stock. After a few hundred miles no leaks or odd noises.
Only caveat: make sure you torque the bolts evenly and correctly I snugged them in a crisscross pattern and rechecked after a short drive. Other than that, just check the fluid level a few times after installation, and you should be good.
PPE 228153010
PPE Cast Aluminum Transmission Pans, SKU 228153000, 228153400, and 228153500 are all compatible with 850RE and 8HP75 transmissions in the Jeep Wrangler/Gladiator. These three pans have different depths and capacity gains.
228153000 has 2.2 quarts of additional capacity, offering maximum thermal capacity. 228153400 has 1.0 quart of additional capacity, offering better ground clearance. 228153500 has 1.0 quart of additional capacity, offering better ground clearance.
The numer on the end 10 or 00 has to do with finish 00 is raw 10 is black and 20 is black (I think).
Went on without a hitch. Reused stock gasket which seemed fine (quality piece). One note is the instructions called for 18-22 lb-ft of torque and that is really too much IMHO for M6 bolts in aluminum. Most online sources recommened no more than 10 lb-ft for m6 in aluminum and this felt much safer. Definitely don't want to strip threads. Did the criss cross torque sequence and have no leaks. I just did the fill with the jeep sitting level.
Read some people jacked up front end, others jacked up rear. Best instructions I could find said park vehicle on level ground. Overfilled potentially worse than underfilled due to cavitation and foaming. Underfilled may run hot which I can monitor, but with the deep pan and extra 2qt capacity, there should be some leeway for underfilling. If anyone has any clarification on level of vehicle.....it would not be a problem to jack the ass up and add more fluid with it running, but I've read conflicting instructions so I went with level.
Just about no way to do this without dripping fluid on the hot crossover pipe when you reach full level, but nothing caught on fire :)
Proper fill level is achieved via instructions posted on first page. If you don’t do it at temp, with trans rail level, and have cycled through gears, you will be under filled. A properly filled transmission would spew oil everywhere will fill plug removed with wheels on ground and engine off.
I went for a drive and then jacked the rear up to level the pan and it held 1 more quart. I get it about the pan being level but seems like a ridiculous fill procedure and there is conflicting information out there to be sure. I bet you there are quite a few of these running around underfilled. One guy commented that you'd basically have to stand the vehicle on its nose to overfill an 8hp tranmission. I get that there is a proper fill level, but how critical is it? Would a quart off REALLY damage anything? Some resources make it sound like being a CUP off is a recipe for disaster and I just don't buy that.
I suppose it’s only critical if you have a failure. If you don’t, great. It’s easy enough to do it right as well. You could prob get away with a couple quarts low in engine oil too : ).
The only reason I mention it.....There is a whole thread on a gladiator forum and they have people on there that claim they called zf to ask specifically and they stated not to level by the transmission, but to have vehicle level. Differences were cited in the stellantis vs the zf procedure. Just frustrating that there is so much misinformation out there that it makes it difficult sometimes to sort fact from fiction. Even the darned instructions for the PPE pan had a questionable torque 18-22 lb-ft on an m6 bolt in aluminum. Way on the high side. Pays to do some due diligence and not just take everything at face value or just go with first thing you read. Not to mention the dangers of using AI because it will sometimes hallucinate some stuff that would have you breaking things for sure.
I will say, having the case level makes the most sense as that would give consistent fill values across different vehicles.
Wondering how these pans are working out and if anyone has run into any snags with the 1 quart version and aftermarket skids?
I have the +2 with Rusty’s skids. No clearance issues. Been on for several years, no issue.
