If you ever think you’ll need to argue about warranty use the ZF lifeguard fluid 8 or Mopar equivalent. If you don’t care about warranty, either of those you have listed are good fluids.Is this the place for
Redline D6 VS Amsoil ATF
ZF lifeguard fluid 8 that's good information. Thank you!!If you ever think you’ll need to argue about warranty use the ZF lifeguard fluid 8 or Mopar equivalent. If you don’t care about warranty, either of those you have listed are good fluids.
Just got off the phone with PPE Tech support - They want "photos of the pan and the leak you are encountering? Pictures of the leak and the pan surface would be great, along with any videos. Also, can I confirm where this pan was purchased from as well?"Okay I need some assistance...I have a leak at bolt #13
I'm on my 3rd attempt of PPE pan install with the latest on a new seal/Gasket.
I'm torqued to 96 inch-pounds (in-lbs) or 8 foot-pounds (ft-lbs) and I'm still seeping @ 13. It's enough to slick the cross exhaust pipe.
What do ya'll think?
Good info. ThanksIf you end up taking the pan down again - make sure you have a known good straight edge and feeler gauges and check that area to ensure it's flat?
Also check the trans to ensure there's not some foreign debris messing up the gasket seal.
Ever get your leak fixed?Just got off the phone with PPE Tech support - They want "photos of the pan and the leak you are encountering? Pictures of the leak and the pan surface would be great, along with any videos. Also, can I confirm where this pan was purchased from as well?"
Before I drop this pan a 4th time any thoughts?
As a side note the Orion Motor Tech Oil Extractor Pump and Dispenser Tool Kit, 10L Pneumatic Transmission Fluid Bleeder Set (Amazon) and the Pro Eagle "KRATOS" has made this project less of a PITA![]()
