- Mar 8, 2021
- 657
- 712
- Current Rides
- 2005 LJR and a 2021 JLR392, "True Wrangler Unlimiteds Only Have 2 Doors"
I know you addressed your question to to "Mike in moss beach" but here is what I have experienced with "disappearing gas". When I'm parked in the garage on flat ground, I back in, with the gas gauge reading between 1/4 to 3/8s full all is well. When I pull forward on to the driveway that has a slight downward slope and leave the Jeep there for a few minutes the low fuel warning comes on and the level indicated on the fuel gauge is either barely visible or even with the bottom of the gauge's range. I suspect that the fuel sending unit is in the rear of the gas tank and the fuel moves away from it thus providing a very low reading. My concern is when off roading and headed downhill for an extended period that the Jeep may actully be starved for fuel at some point as generally the fuel pump and the sending unit are co-located.Not sure what you mean by "disappearing gas on my gauge issue". Do you mean the gas tank level, per the gas gauge, is going down without driving it?
