Huge NoLimitz Feature Release (Beta)
Received mine today and its on 24.0.5 so I emailed them to try to get the latest which looks like 24.1.5?
Mine comes tomorrow but I emailed them today and asked them to send me the Beta file. They sent it within an hour.
I hope I grow up to be like you 🤣 thinking ahead why didn’t I think of that 🤣
Edit they emailed it to me first thing this morning 👍
I installed mine today and must say i really like sport mode. My only complaint is there is no delay on auto lock down when starting to enter the code like there is with the Tazer unless I’m doing something wrong I will probably disable that. I was going to email Z about adding a delay.
100% the start after entering the pin is something it almost startles me each time :)
Same here when the brakes lock lol. I’m not sure if that is disabled (no code to start? ) of how all the other security items get triggered
I just disabled the brake lock down and panic for now so every time I try to start it I don’t hear the noise of the brakes and flashing light lol
Torque limit is a little confusing. I believe the lower the number, the more limited it is, correct?
I have mine set to off and I am heading to the trails so hopefully my Torque is unlimited.
I skipped all the security features since I have IGLA.
Also discovered that 105 mph on 40s, in 25 mph wind is scary. It felt like I was going 253 mph.
From watching the Z video, I believe that you have it set correctly (off) to have full torque.
It was so slick, muddy and wet that I couldn't tell anything.
I think these quick enable functions should both be activated by turning the engine "OFF". If I find that I am about to park at a risky location that I want the security to be quick enabled, I should be able to (HOLD) CRUISE SET+ + TURN OFF VEHICLE to "ENABLE", since the engine is already running when I arrive.
Makes sense. Let them know.
I sent them an email with this request, as well as reiterating the request made by @WhiteBronze392 for a delay timer on the auto-lockdown . I really like the Sport Mode, MDS Toggle, and RF Hub Block. This is a really good product and If they can manage to incorporate the two changes mentioned above, then the Security Lockdown feature will be more feasible to use as well.
This must either be a typo, or they changed firmware 24.1.5 just before I downloaded it
because I just went out to the garage to test it and it operates exactly the way I suggested. I tested both "Quick Enable" and "Quick Disable" and they both work while the engine is running and you turn it off. I went back and watched the video again very closely and he explains that both functions are with the engine running and then you turn it off :cool:
Can anyone report back how the NoLimits and Tazer work together with force 2wd, no mds, and sport mode?
I saw in earlier comments that sport mode + no mds sounds like off-road plus mode button without the altered shift points.
Can anyone confirm?
Can anyone confirm?
Here's the email answer I received from Scott at ZAuto to a similar question...
"I spoke with our engineer on Sport mode and it is the engine component only, making the gives you a more responsive experience from the engine power. No update to the shift table, and this part of the offroad+ isn't used by the no limitz."
Unfortunately, his response only answered a portion of my question. Given the update is still in beta, perhaps they're still making additional changes.
I'm Offroad+ 95% of the time. I would say Sport Mode is mainly just the engine sounds without any of the other advantages.
I still reach for the Offroad+ button each time I am in the Jeep.
Wow, Z Auto is listening to their customers with a huge new firmware beta:
Just received an email from Scott at ZAutomotive that they found a problem with the beta firmware and will be sending another update out today to make things right.
It appears there will be many updates with new features coming out in the near future.
"I do have another firmware to update your no limitz too. Our engineer found an issue, that causes the no limitz to overwrite in a continuous manner and this can wear out the unit. So we have an update coming today to resolve this and I will send this out to you as soon as we have it out. No harm to the vehicle but could prematurely wear out the unit and this update will prevent that."
