They all have ANC…. They all do it. It’s whether you notice it or not. Here’s a good explanation of how the system is designed to work (From another Jeep forum):
The Active Noise Cancellation System is system is designed to address the change in exhaust noise whenever the vehicle is operating in Fuel Economy Mode (ECO) or 4 cylinder mode. The system relies on four microphones embedded in the headliner to detect the exhaust drone and prompt an onboard frequency generator to create counteracting sound waves through the audio system's speakers and sub-woofer. This helps keep the vehicle quiet at highway speeds.
The Active Noise Control (ANC) module performs the creation of signals appropriate to cancel engine order related vehicle noises from the engine. It creates these signals in proportion to the Engine RPM plus any other needed input.
...The ANC module obtains the engine RPM from the vehicle Powertrain Control Module (PCM).
...The signals that the ANC module creates includes at least four simultaneous signals equivalent to sine wave frequencies in designated ratios tracking the engine RPM, to cancel engine order related noises, plus other optional signals that can enhance the cancellation effect.
...To maintain the effectiveness of the noise cancellation over the full range of vehicle operating conditions and seating locations, the ANC module has four outputs and process signals from four microphone assemblies located in the headliner.
...The ANC module supports mixing the four ANC signals into any output channel at a point after all of the signal processing required
...The ANC module operates on vehicle battery power and has its state of operation controlled by CAN-B bus messages.
Like I said in earlier posts it doesn’t bother me.
@Sulley go to a dealer that has a used 392 and ask to take it for a test drive. That’s what I did before buying mine. There are definitely people that are more sensitive to it and it annoys them.
If you make changes to the audio system and don’t know your way around the ANC system it seems to magnify the noises that it makes (and not in a good way).
