Radio cut out for a second when opening sky top
Has this happens it anyone else?
Do you have a tazer?
My radio has cut out at random times, but not here recently. It mentioned this in the tazer manual about not having the navigation set where you could adjust it while driving all the time because it might mess with the radio. Happens rarely enough that I leave the navigation where I can adjust it while driving.
My 2013 JKUR did a weird thing that I think is due to a lot of things running off an can bus. Sometimes when I would put the right blinker on, it would trigger the windshield wipers. They would just sweep 1 time and then stop.
If it only did it once, or only does it occasionally, I would not worry about it.
If you are listening to Sat radio, the antenna is on top of the sound bar I believe. So, the radio looses signal as the header bar on the SOT passes over.
Or at least that what I remember from my 2019.
Totally normal, mine does the same thing, it is designed that way. There are two audio modes, top closed and top open. When the top reaches the full open it sends a signal to the audio to switch modes.
:)(y)
Here it is in the manual:
Mine constantly cuts in and out on Sirius XM when I open the top partially. It never happens when 100% open or closed
No Tazer strictly stock
:)(y)
THANK YOU VERY MUCH!!!
:)(y)
When all else fails, read the instructions :). I love it.
