I have the Warn Evo 10 with the Warn plate. Fit perfectly, no issues
HiI have the Warn Evo 10 with the Warn plate. Fit perfectly, no issues.
Yes the warn winch plate does push the bumper forward. Put the four front skid plate bolts in first then you will have to drill out new holes for the two rear bolts. Some people have gotten away with just slotting the rear holes.Hi
I tried to mount my warn winch plate it’s giving me hard time the skid plate not aligning with the screws under there is 4 screws and it’s almost 1/2-3/4 inch forward it feels the winch plate pushing my pumper out any fead back please ?
Do the Grimm and Maximus 3 plates also require this modification?Hi
I have seen were most people were able to use a round file and slot the holes out by just an 1/8 - 1/4 inch for a better fit. Nothing major.I was able to get my skid plate back on without modification with the Warn winch plate. I put back bolts on first, loosely, then front also loosely, then tightened everything down. Weird that it varies for different folks with the same configuration, but clearly it does.
You would think a guy could mount a Warn winch using the Warn winch plate without modifications on a factory Jeep bumper, but for whatever reason it seems like some can and some can’t.
Not that any of these modifications are that difficult to perform, but you would think that one of these plates would be a direct bolt-on if using a Warn winch (which most seem to be).
Thanks manYes the warn winch plate does push the bumper forward. Put the four front skid plate bolts in first then you will have to drill out new holes for the two rear bolts. Some people have gotten away with just slotting the rear holes.
Wondering why I don't see many remote mount the winch's power control module into the engine bay for a more low profile look?
I'm considering the Warn Zeon 12s (along with Warn Long Control Pack Relocation Kit -92193).
Any unknown issues doing this?
I guess no one else is going to say it so I will, 95% of Jeeps that get winches will never use it. They want everyone to see it, they dont want to go low profile or then no one can see it.Wondering why I don't see many remote mount the winch's power control module into the engine bay for a more low profile look?
Ok, that ever crossed my mind. I come from the harder core rock crawling world, where winching is a show of defeat, but sometimes has to be done.I guess no one else is going to say it so I will, 95% of Jeeps that get winches will never use it. They want everyone to see it, they dont want to go low profile or then no one can see it.
I am with you, I could care less what others see etc but moving it in to the engine bay is not where people normally put it, they put it in the cab of the vehicle.
definetly keep the 03, not sure what the scenario is when you are using winch but there is a blluetooth controller that is run by an app on your phone and some wireless controllers. that way you can leave all as it is normally and add one of those options and you avoid having to go to the winch and be next to it as you can control it from the cab.Ok, that ever crossed my mind. I come from the harder core rock crawling world, where winching is a show of defeat, but sometimes has to be done.
With this Jeep, I don't see myself going out and bashing it up any time soon. May hold on to my built 03' LJ (6.1 Hemi, dana 60's, 42" sticky Treps) for that?
However in FL we have sand and mud that can sometimes be deceiving. Windrock in TN, is also a favorite wheeling spot of mine and again with this Jeep I will probably winch up instead of my normal try it until you make it.
Yes, and thank you for the reply.definetly keep the 03, not sure what the scenario is when you are using winch but there is a blluetooth controller that is run by an app on your phone and some wireless controllers. that way you can leave all as it is normally and add one of those options and you avoid having to go to the winch and be next to it as you can control it from the cab.
Where did you get your filler plates?I have the Warn Evo 10 with the Warn plate. Fit perfectly, no issues.
