I also did a spare tire delete. My 392 XR came with the Mopar reinforced tailgate hinge but it stills works with the Body Guard spare tire delete. The reinforced hinge still gets used to support my tailgate table. I liked the Body Guard because of how it integrates the brake light.
Installed a spare tire delete kit...gonna try it out through the winter.
Did you take any pictures of the components? I working on a thing where I can swap from a tire delete to a teraflex carrier and back and forth easily while keeping factory light and camera.
Have to say 392 aev lift and front stabilizer is amazing. So much better than the recon pkg . The ride is so nice and front end steering perfect. Rides like my Lincoln Navigator. So Happy with it. Off roading here we come
Thanks for that update. Great to hear!
What components do you suppose are making the steering feel improved? The stabilizer is just masking softening road inputs....
Maybe whatever is in the "AEV 2.5" DualSport RT Suspension System"
I have geometry correction brackets (as the AEV package has) and cant say it made any difference
@Viking Jeeper - I went from a Smittybilt carrier to the tire delete, so no pics of any components. The delete kit is made up of four pieces that are very simple to assemble.
Test fit a passenger side Challenger style coil cover on the Jeep (passenger looked to be worst for interference). Fits with some trimming on the forward side of cover. I personally prefer it to the gold/carbon look Jeep 392 covers.
Driver side is next.
Passenger side is next.
You probably posted here but I dont know: did you paint your caps or buy different ones?
They are from Billet Technology except the washer reservoir which is Auto Gear Direct. The PCV cover and dip stick handle both required some modification to work.
Installed…
-GG tailgate table
-Bulletpoint dash mounts for tablet and GoPro (so far)
-Midland MXT575 (behind driver kick panel)
-grab handles
-Smittybilt X20 Gen3 10K winch
-Jeep Unique mount for a Midland handheld and MXT575
-rear window LED light (hardwiring to come)
Installed…
-GG tailgate table
-grab handles
Thanks flynbvr! I really like the way you ran the wire for the liftgate light and would like to know more about your plans to complete the hardwiring. I have the same light and am pondering how to hardwire it neatly and have several ideas none of which include the 12 volt outlet. 1. Wire to the dome lights; 2. Run dedicated large gauge wiring from the battery and install a multi junction connection box of some sort in the rear of the Jeep to also accomdate additional accessories; 3. Other ideas as they occur.
In reference to your comment that the front control arms were previously replaced... what was the reason for doing so?
I installed the Mopar ones used for the 2" lift. Approx. 1/4 inch longer, provides approx. 2 degrees more caster. Steers much better.
Thank you! Could I get the part numbers please?
Got a bit done today. Installed a Tazer Mini and programmed most of the features. Did the first oil & filter change at 1849 miles. Then installed 1" front spacers to level it out. Had previously installed the Mopar lower control arms.View attachment 8042View attachment 8043View attachment 8044View attachment 8045
Just got the mopar 2 inch liftlower control arms.
Did you have to get an alignment after?
Having my shop install them on Thursday and they said I’ll need an alignment after because it changes my caster.
No alignment needed. That is the whole point, changing the caster. It is only about 2 degrees which is enough to feel improvement without adding to much angle to the front driveline.
As of right now my plan is to tap into the CLA behind the panel using a quadratec OEM plug/loom. I havent yet pulled the panel so I havent confirmed if it’ll work. I hate using vampire style wire taps and I certainly dont want to cut any OEM wiring. Im also hoping to replace the CLA with a more useful outlet (multi-port usb) and then move the CLA to a better more protected location like at the base of the roll bar but facing forward. This may allow me to use the quadratec plug in a modified fashion if plan A isnt possible. Ill post pics of whatever I come/end up with.
