Damn hate to read this. Best of luck on that fight.I wish I could say I don't have it. Working on my toys is a good distraction though.
Sorry to hear that.Ted how did you get to the stabilizer bolts on the Oem bracket as I could only get 2-13mm bolts out as I don’t have access to a lift. I had to re install the stock stabilizer as wrenches were just stripping the 3rd bolt. Appreciate any help.
There is actually a bar straight in front of the bracket so close I could not get the 13mm socket on it. I don’t know what they call it as ot bends over the Dana axle. If I could get this to move out an inch I’ve got it.Sorry to hear that.
My axle bracket lined up perfectly. No issues with the 3 bolts. I might have read that there are different brackets, so perhaps you can contact seller and ask them.
That would work. Thanks a bunch.You mean the track bar? I used a ratchet wrench on the 3 stabilizer bolts, tight fit it is.
Thanks Ted just picked up a set and will install tomorrow.That would work. Thanks a bunch.
What site did you order it through for this?That rubber really does make a difference. Works very well.
I bought mine from Amazon https://www.amazon.com/dp/B00NL4DI2E?tag=jeep392-20What site did you order it through for this?
