RKKRAWL Hydro Blue Build
What's that saying about idle hands 😁 Well, since I'm still waiting for parts and can't use the Jeep might as well do something! Guess what's next?
Got the tune installed today, transmission changes alone are worth the money. I'm running the 91 tune for now and this is the first time I've ever seen the range mileage going up as I'm driving, at this rate even a 2 mpg rate it will pay for itself at the rate of $20 dollars a tank. Mid range performance is night and day difference and will almost snap your neck if you're not paying attention, well worth the money.
Finally got my Next Venture Motorsports front Featherweight Bumper. Got all put together but still have to wire the lights and winch. The Apex cooler was not a problem there's enough clearance for air flow and nothing rubs or was in the way. Finally, can take it out and wheel it, instead of it just gathering dust in the garage.
Who’s tune did you use? What price range did that run?
That's what I'm thinking not sure the cooler will fit by just bending the bracket down, I have a Warn winch plate and a Zeon 12S Platinum and It sure is a tight fit, not much room at all behind the winch plate. Your build is coming along nicely and looks great! Thanks for the info!
Did you ever get your Apex steering installed? I have the same setup and wanted to see if everything fit.
Look a few topics up, installed the New Venture Bumper and winch plate. Cleared the cooler with no problems. Everything fits but the 392 is slightly different, I found it was easier to take out the pump to work on it. The new pressure switch is straight up the frame rail near the back of the pump.
Hi. Love your build and also have a hydro blue 392. Would you be so kind as to tell me the part # for the Quake sequential lights? Thanks!
I like those lights but when I check quakeled.com they say they have nothing for a 2020 JL (no option for 21) and no part number QTE993.
I called them, and verified that the QTE993 are available. For some reason it is hard to find on their site (use the search function). There are also variants with RGB leds, and also smoke-colored diffusers.
QTE993 was the kit that I used
I ordered some too. I notice you decided to keep most of the lower fender and just cut it flush behind the lights, rather than remove it entirely. Was that jus a design choice, or does it work better with the fender liners?
I actually cut it next to the lip to keep the trim on the outer edge. If I had to do it again I might try just removing the raised center portion of the fender under the splash shield and keeping the rear support for more strenght.
Hopefully solved my front license plate mounting problem.
Two quick follow-up questions (sorry for being a pain!):
(1) Is the (black plastic) trim on the outer edge bonded well enough to the shell that it stays, even with the rest of the black plastic removed?
(2) Did you somehow preserve the two rivets furthest the back (that go through the trim) and were used to secure the inner fender? Normally I see people cut those off at the beginning of the fender-chop process to remove the liner, but if I wanted to keep the trim like you did, I guess I should try to keep those in place if possible.
Thanks!
The black trim is anchored to the fender by clips and will stay once inserted, Sometimes you can remove the rivet with a punch in the center, most times you will need to drill them out. You can get replacement rivets that will work through Harbor Freight or Amazon. Pictures of cut trim, last is of inner fender support. You might be able to just remove the center box section and trim the front for the light.
Thanks so much for the info and the pics. Really helpful. Waiting on my AAL fender liners before I start the work.
One more simple question: Did you also pull out the inner (black plastic) fender support structure on the rear wheels? I know you put fender liners on there, but I can't tell from the side-profile photo if you removed the inner fender support or if you just trimmed it like on the front. I have been looking closely at the rear fenders (and bumper) on my jeep and trying to imagine how it would look if I don't match the fender-chop front and rear. My thoughts are that if I maintain the outer black trim on the front, then I need to do the same on the rear. Or vice versa.
The back fenders don't have any support just in the inner liner which has push pins to the body and rivet to the lip moulding.
Finished the rear bumper install, now to hook-up the wiring for the rear flood lights.
Check the bottom frame horns for welding burrs, grind down if necessary.
You might need 2 longer frame bolts on the rear most bolt holes.
If you have backup sensors they might not snap all the way in unless you file the flats between the tensioner tabs even with the notches next to the tabs. Then you hear a definite click when you push them into the housing.
Installed the backup sensors with the inward 2 facing up like stock and had to position the outer 2 facing out instead of inward to sense the corners.
You can reach the supplied bolt hole plates through the rear most bottom bolt hole to hold them in position while installing the rear most side bolts.
Thanks again for all the help and inspiration. I assume you re-used the original wire harness for the back-up sensors and kept the connector behind the bumper on the drivers side. If so, did you just terminate the wire that would have led to the original license plate light, and then splice into the passenger side tail-light for your relocated license plate light?
