Finished the rear bumper install, now to hook-up the wiring for the rear flood lights.
Check the bottom frame horns for welding burrs, grind down if necessary.
You might need 2 longer frame bolts on the rear most bolt holes.
If you have backup sensors they might not snap all the way in unless you file the flats between the tensioner tabs even with the notches next to the tabs. Then you hear a definite click when you push them into the housing.
Installed the backup sensors with the inward 2 facing up like stock and had to position the outer 2 facing out instead of inward to sense the corners.
You can reach the supplied bolt hole plates through the rear most bottom bolt hole to hold them in position while installing the rear most side bolts.
