I have been putting this off for long enough. Finally decided to install the Artec diff covers I bought last July.
I had planned to remove and fill the locker sensors with potting compound, but since I have a later model year 2023, both of my axles have the newer sensors that are revised/sealed from the factory to prevent oil from shorting the PCB as was common in the older style sensors. No need for me to do any potting!!
Both front and rear diff fluids looked great with about 7700 miles on the Jeep. There was very minor build up on both OEM fill plug magnets, which was well within the norm for break-in. The OEM 4.56 gears looked fantastic.
I’m switching over to Amsoil 75w-140 gear oil in both. I spoke with Artec and they advised to fill until fluid dribbled from the fill hole, much like the transfer case.
Excuse the fill plugs being loose, I hadn’t yet put in the fluid when I took these pictures.
I checked clearance on the front cover at both left and right full lock and have plenty of it. I was initially concerned because I have the CurrectLync steering tie rod and a relocated Falcon Nexxus steering Stabilizer. No issues at all!
