3 front center, hood air inlet marker lights??
Thank you, ordered these and the gorilla mount tape...
Is there a way to wire this to another circuit so they always come on every time I start up, without using my last available AUX slot?
Also got some Rigid Radiance amber pods to mount at the A-pillars to get a nice line of amber up at the roof line between these Raptor lights and the Rigids... let's find out. Thanks again.
I tapped into the parking light wire on the right fender. You have to pull back the inner fender liner to access it, and I don't remember which wire it is- but there are only a couple (signal wire, daytime running light, etc.). So mine come on whenever my lights come on- as does the ambient light on my 10" bumper light bar.
You could use a fuse tap and tap the F52 fuse. It’s a 20 Amp for the “Cigar Ltr” per the user manual and is tied to ignition.
Anyone know how I can get 3 YELLOW lights in the scoop not Amber or Orange?? Needs to be yellow like a true fog light or even white. Thanks!
@Quadjeeper yours looks the best by far. Any more info? L:ike what lights? better Pic? I REALLY want to steal this mod.
I had a link/description awhile back in this thread. Can't do any better pics as it is out of sight intentionally.
The amber matches the Rigid Radiance amber pod backlighting 1:1 in person. Couldn't be happier. Thankful for this thread.
I’m still looking for a yellow version, not the amber (orange)
From a past tuner life, iirc that color is ~3500 Kelvin temp, and can most easily be found searching for the descriptor "JDM" or "JDM Yellow"
Just finished installing mine.
In my case I was able to find some used TRX marker lights for cheap and bought a new wiring harness that goes along with it. I used a bit of epoxy and zip ties to permanently fix the LEDs to the hood scoop. It came out better than I expected and looks like OEM
OEM Ford Raptor-esque. 😜
I like this idea. Anyone have experience with this kit? Would it interfere with the front camera?
Just seeing this post, I run this kit on mine, it's great, and no interference with the front camera.
I saw Dirt Road Cred (Youtube) came out with their own larger "prerunner" lights for the grille.
They are larger, up to 5 lights, and are color changing (If you seek a color other than the traditional amber.)
That channel hawks chinesium junk.I have not seen their prerunner lights, but would avoid them and stick w an American made brand like Diode Dynamics or Oracle
Went with oracle and attached to the brown and white cord on the running lights. It took about 20 minutes but I will probably have a buddy wire it up a bit better next time he is in town. I attached photos of the Oracle recommended set up and I just used Gorilla tape for the lights. I also did not take off the hydro guide but simply pushed the wire through it to the back of the hood where the rubber flaps are. Pro tip- cut off the plastic pieces on the edge of the lights. I didn't do that initially.
I am not a DIYer so feedback is always appreciated.
Double sided tape
I had some gorilla grip double sided tape holding up the hinge to my homemade tailgate table on my LJ for years but I think the hood intake is a more challenging environment.
