3 front center, hood air inlet marker lights??
Double sided tape and underneath the hydroglide scoop to aux 4 where my other baja back lit amber lights are triggered.
I just picked this up, when you get the chance do you mind showing us what underneath the hood looks like.
I assume you removed the hydro glide
Interesting 🤔 I like what I’m seeing….
Was wondering the same. Just took a look - 1001 routes, but would love to see/hear the route you took. Thanks!
Chris
Sorry I never took pics under the hood of mine, but the hydro guide has two main pieces, and the one big one fits over the other. You only have to remove the one piece that comes off first. There is a bunch of sound-deadening foam that's held to the underside of the hood using plastic pins, (the big pop-out kind), so I just popped a few of those off to route the wires underneath it before bringing them down to the base of the hood on the passenger side where they could be threaded into the engine bay near the battery. I opted to not wire them via the AUX switches and splice into the passenger side parking lamp so they'll be powered whenever my headlights or parking lights come on. To access the parking wires, you have to pull back some of the inner fender liner on the passenger front...more push pins. There are only 2 parking wires, one black, one white. Doesn't matter which order you splice in (or T-tap, etc.). I love the look of the lights...it's my fav useless mod so far!
Awesome - thanks for the info!
Chris
Do they offer these in yellow instead of orange to match yellow fog lights?
Man I’ve been trying to get very similar lights to work and they keep going out on me 😔
Fleabay, item: 2 AMBER BRIGHT 8 inch 12 LED Waterproof Flexible Light Strip BLACK PCB board
still waiting to find this out lol.
The hydro glide easily detaches expose that area. Just a few screws to loosen. I just ran mine down the left side on the battery side straight to the battery and aux switch wires. I used adhesive plastic C clips to secure the wire down the hood. Pretty simple overall.
Take the hydro guide off (it comes off in one easy piece) and route the wires down along the underside of the hood. I used the 3M zip tie mounts to secure and route on hood and brought the wires out via the existing wire channel at the bottom of the hood above the firewall. Then route in the engine bay to wherever your ‘re sourcing power. I put mine on one of the aux switches. Make sure to leave enough slack for opening/closing the hood. Put the hydro guide back on and you’re good to go. The wires won’t interfere.
Thank you, ordered these and the gorilla mount tape...
Is there a way to wire this to another circuit so they always come on every time I start up, without using my last available AUX slot?
Also got some Rigid Radiance amber pods to mount at the A-pillars to get a nice line of amber up at the roof line between these Raptor lights and the Rigids... let's find out. Thanks again.
