1st Oil Change
Newbie questions- what size socket to remove the oil plug, and do you use a torque wrench to put it back on?
Also- how many turns to put the oil filter back on?
Also also- how much oil did you use?
Reactions: dog
Actually depends on when your 392 was made. Aluminum pan or steel? I know the aluminum pan drain plug is 13mm. And it holds 6+qts with a regular oil change. I think the steel one holds more. But check your manual for how much, understand the number they give is total capacity and you will be a little less because you won’t get every drop out when you drain…
since the 899 and 339 are interchangeable filters…. They use the same 15/93 wrench(y)
NOPE! The 899 is much bigger. If you are using a cap type oil filter tool that has a specific size and flutes number, the two filters will absolutely not use the same wrench.
For anyone else looking at this thread, I did a quick Google search and 76mm/14 flute cap wrench should be the right size for the factory filter MO-339.
Wait, you guys have oil filter wrenches? I thought the standard SOP for removing stuck oil filters was to drive a flat head through it... :ROFLMAO:
Oh man, why would I even need to buy a filter wrench just to get rid of the old smaller filter? Thumbs up to the flat head idea(y):LOL:
The gasket of the 339 is slightly smaller than the gasket on the 899. Anyone else notice that?
The difference is slight enough that I didn't notice it. 899 works fine.
I did take mine in for an oil change today (free Jeep Wave) and they filled it right up to max on dipstick. No leaks. They used the 339 filter. I changed the oil myself at 1500 or so miles just to fresh oil in it after initial break in. I used the 899. They did not comment on filter I had used.
Are the 041 SRT filters easier to get these days? I put an order of 15 in with a company a few months ago and I’ve been notified they’ve been shipped just now.
They’ve been on backorder for a while.
Well I have a pack of 15 and would sell some for $18 shipped if anybody needs one.
Mine are on the way as well. Ordered months ago. Got 3 coming. Gonna cut one open. I'm betting they are not going to be as nice as the Wix 57899XP but will see
K@N fixed me up nicely with their K@N HP 2010 recommended filter for a 6.2 Jeep TrackHawk, crosses over to the Mopar 041 SRT filter.. K@N HP 1017 replacement filter for a 392..
AmsOil offers a 0w-40 Signature oil
Same filter I ran on my GC SRT.
have you signed up to be an Amsoil vendor? It’s worth it.
You can sign up as a Preferred Customer getting a nice discount along with free shipping on orders over $100.
the signature 0w-40 runs about $12.50 a quart.
I held my vendor status with them for a long time but eventually stopped.
