- Jun 27, 2024
- 501
- 1,403
- Current Rides
- 2024 JLU 392, 1997 TJ, 2025 McLaren 750 Spider, 2024 F450, 1954 Jeep M38A1, 1996 Mazda Scrum KEI Truck
Yes, IMO, I would replace everything with PSC as it was all designed together. If you leave the stock pump but add APEX, it still isn't the system PSC designed. Not saying it won't work, but when you have issues, 1st thing pointed to could potentially be the pump. Now if you're ok doing the labor yourself, I would possibly keep the stock pump with APEX and see how it does. Then just change it out later to PSC if you have issues. But if you're paying for labor, I wouldn't do it twice, just go PSC from the start. We have more issues with the PSC lines than anything, so you'll probably be chasing those gremlins more as well as small leaks from the box itself.@jeepguru , I'm interested in your thoughts on the PSC kits. I'm trying to decide between, keeping the stock electric pump and adding the Apex booster, replacing the electric pump with a PSC electric pump, or changing to the PSC kit with the belt driven pump.
I'm also debating between the new Apex through shaft kit and the PSC ram setups.
Any experience/opinions you can share?
As for the APEX through shaft kit, if I had or planned to keep my stock D44, I'd do it in a heartbeat. Based on the videos and feedback I've read, it's a great set up. Plus the cost is that much less than PSC and could potentially provide all the steering control you'll need. I also really like how they thought out the line placement along the axle and up the driver's side. Unfortunately for me, the kit isn't compatible with aftermarket axles because of the way they force you to mount it where the OEM stabilizer used to reside. It would take too much modification to try and make it work on a D60 or something non-OEM.
Dave
