Featured
- #2,441
7.62you need to downgrade to 5.56 that’s a lot of wire just joking![]()
I bought these before I realized they don't work with the one touch top we have.Added Rockworkx bolts for the hardtop.
great video, nice clean install.I finished my video of the Thor's Lightning Total Control air compressor bundle install. If anyone wants to zip through the video:
Clean lookI added a paper towel holder. Yes...I am bored...View attachment 35260
Maybe it means that it’s “their” lowest deployed steps as in AMP. They use the term PowerStep to describe their own products.Question for other Amp Research XL power step owners..... does drop of set look correct?
I thought it would have been lower after reading the description on Amp Research web site. Stated it drops 4" lower than other steps?
Is that just because the housing bolted to frame is lower/thicker or are the drop arms supposed to be longer?
LOWEST DEPLOYED STEP
PowerStep XL Running Boards drop 4" lower than the other PowerStep boards, making them perfect for lifted trucks or vehicles with higher ground clearance. Also, most stationary running boards rest 1-2 inches below the body and are often too far from the ground for many passengers.
I have RSE as well on my rock custom LJ. Went with Amp, for now, due to wider step and smoother operation. My 392 is currently used as a run around vehicle and light trails. I know what it takes to build a safe & reliable rock rig with 42"+ tires. Hope guys that are hitting the harder trails have a full roll cage with harness. I've witnessed some bad roll overs in the last 20+ years of rock crawling.I have them on my TRX, RSE on my 392
NiceUtah Design Foundry. His comes with a rubber gasket.
Just saw your postAnyone having issue when trying to mount cover plates behind factory LED fog lights?
I purchased a set a of metal flat cover plates a year ago and just got around to installing. Mine contacted with back of plug for factory fog lights.
Would not bolt on without crushing wire in back of plug.
I've seen so many on this forum install the same ones, are you just forcing them on against fog light plug? (2023 XR)
Any chance mine has odd light plugs?
View attachment 35313View attachment 35346
i just your post in the other thread…so they are UDF, mine sit just at the wires. Not crushing them. The gasket fills that space. That gap looks wider than mine tho.Anyone having issue when trying to mount cover plates behind factory LED fog lights?
