I have no expertise or experience. But..... I plan on going with the Fox ATS stabilizer here is why.
It seems to me one of the biggest complaints I hear about the Jeep Wrangler is "vague/sloppy" steering. I have been researching what remedies exist and the 5 main "fixes" I will explore in order are:
1. Add the Fox ATS steering stabilizer; The fact that it is fully adjustable and neurally dampened with the Adjustable Through Shaft seems like a perfect solution and easy to replace and fine tune myself. I have had great experience with FOX in the past and I know the engineering is well thought out.
2. Use the correct tire pressure; using the old chalk on the tread technique to make sure the tires are properly inflated and making ideal ground contact for nice sure footed tracking.
3. Get the TSB (08-074-20) done to replace the Aluminum steering box with the Steel Steering box. I would hope all new 392 should come with the updated steel steering box from the factory.
4. Add the
Synergy Track bar reinforcement and Sector Shaft Brace to prevent any defection of the steering box. I would hope the new steering box TSB would make this step unnecessary.
5. If there is still play them I may consider adjusting the backlash in the steering box as described in this video to help work out some of the play, I hope this is also unnecessary:
