Stalling after spinning (on obstacles)
Have they fixed the No Limitz yet? I was thinking of getting one to eliminate cylinder deactivation. I’m guessing that’s not the problem in this case though. I think it’s deactivated in 4-low.
I am uncertain if it's truly fixed. I was in the Beta program and they lack of updates and communication made me bail out.
I get pretty aggressive in the rocks so I use M1 and M2 to avoid wheel spin. It works out great and can really save you on those obstacles where your back-end could kick out and cause a rollover 😉
I normally am in manual mode too. I need to pay attention to if it cuts torque when in manual or if I am in auto when it occurs.
I will see if I can fine a video of it cutting power.
They had some software problems early on but since the current version (24.1.8) came out mine has been working perfectly. Maybe time to give it a (another) try.
Please update this thread when you get an answer so we can all learn things.
As per what I found online and Scott Blum mentioning the same...
Has to do with the 8 speed not having overrun clutches in them and if you stop or slightly go backwards, while in drive, the trans will stall out the engine. He also mentioned he can easily recreate it with his 3.6.
The fix forward?
Adjusting driving style, not fully lifting off the gas, just barely keep some pressure on there to keep it from stalling. So for me, left foot braking even when lockers are on only while doing the more interesting obstacles. My habit is that once lockers are on, I usually don't left foot brake much. Not a big difference in technique as I am already used to LFB.
The fix forward?
Retarded idea - in days long gone by (YJs), an easy fix for raising idle speed was to add a hand throttle. Those were as simple as a cable operated throttle that ran to the throttle body.. Typically these were hung on the shift lever, and you could tweak idle as needed as you worked your way over obstacles (since they were manual gear boxes w/ a clutch).
The only problem is now since it’s fly by wire… anybody got an idea how we could hang an adjustable throttle in the current system?
Put this on the dash
The fix forward?
Makes sense to me. Reading this makes me think I use left foot braking more often than you do, and I haven't had this problem. Thanks for the follow up info.
Maybe reach out to the Tazer team for a software patch. Would be cool to use the cruise buttons to raise and lower throttle off-road.
If you are going slow enough in low range the select-speed control does this pretty well. I do wish it worked at speeds over 5mph or whatever. Having a speed control that worked up to the 20mph low speed cutoff of the ACC would be great for those trails that are not so rough that you need to be going under 5mph but too rough to go over 20.
In the course of looking for something else - found this.
"Tazer has a winch mode that raises idle speed to 1300". Looked at the webpage, (https://www.zautomotive.com/products/z_tzr_jlm), and about half way down the features page,
"Winch Mode – raise idle RPM to user-selected value between 1250 and 2000 (excl. 4XE)", so yes... you could set a higher idle value, and trigger this as required.
Huh, the more things change, the more they stay the same...
