- Nov 5, 2023
- 1,463
- 2,612
- Current Rides
- 2023 Wrangler Rubicon 392, 2024 Wrangler Rubicon X
The bigger Odessey was a perfect fit.Does it clamp down same as the stock battery did ? Thought I read not compatible on this thread.
Thanks
Thanks
Thank-youThe bigger Odessey was a perfect fit.
I do. I have all my vehicles wired up for quick connection to a trickle charger, "a battery tender'. It's good to use. I got fifteen years on the original batteries on my 2005 Dodge ram 2500 CTD.Just wondering if you regularly use a battery tender?
Checking in on how the Anti-gravity is doing. We have two 392's and both of them have battery issues in both the summer and currently when temps have been down under 40F.I pulled the trigger and installed the Antigravity H7/Group-94R Lithium Battery - 80Ah. Caught it on sale for 10% off. My review:
Con: Expensive.
Pros: Engine start up (turns over fast); Battery life; Rock Slide Steps never dead/slow; Aux Switches don't shut off from low battery from normal use of accessories with engine off; Great for heavy load from aftermarket amps; Easy install; Lighter weight; Obvious quality;
this sounds incredible. I've got electric steps, winch, way too much rigid lighting, and a tazer. Think this might be the only viable step for me and my bride to have peace of mind with our jeeps. The only thing is that it does get down below 23F here in Houston one or two days of the year. I read that you can 'warm up' the AG's by turning on your lights for a few mins which creates enough draw for the AG to heat up on its own, such that the start is no longer below 23F where it's limit is at. If that actually works, I think I can live with it.The Antigravity is expensive but it has been a great investment for me. The Jeep can sit for a month with no charger and start no problem. Engine turns over fast. I have electric steps, rocks lights and aftermarket amplifiers for the stereo and can run for hours without the engine running. Never have to worry about the steps draining the battery. I have left the rock lights on overnight and no problem starting.
I didn't install the electric steps for just that reason, they draw a S&%T ton of power.Not sure about cool weather use. I'm in North Florida and have not experienced a problem but 20 degree weather is very rare here. I got the 80 Ah but honestly have not idea what is needed. I just bought the big one so I would never have a problem . . . at the time, I had enough of my electric steps killing the battery.
There's where I'm Kinda at too. Either I find a way to deal with the under-rated alternator in these things or I'm selling them both and getting a 4-cylinder Toyota.Not sure about cool weather use. I'm in North Florida and have not experienced a problem but 20 degree weather is very rare here. I got the 80 Ah but honestly have not idea what is needed. I just bought the big one so I would never have a problem . . . at the time, I had enough of my electric steps killing the battery.
There is a way to deal with the alternator. Marco (ovrlndx) suggest this place does a beautiful job, they can use the OEM housing and make a nice setup for you:There's where I'm Kinda at too. Either I find a way to deal with the under-rated alternator in these things or I'm selling them both and getting a 4-cylinder Toyota.![]()
What’s the alternator issue? Haven’t heard of that yet….There is a way to deal with the alternator. Marco (ovrlndx) suggest this place does a beautiful job, they can use the OEM housing and make a nice setup for you:
Video is here:
I don't recall the specs mentioned but when I took mine in the service tech mentioned the alternators in these 392 application are under-rated and that this is why the batteries don't last long even being AGM's. Wish o recalled more info. I'm on our second battery on one jeep and only 12k miles on her. The wife's has 18k and without using a tender every night, it only goes a few days before it barely turns over. But when I bring it in, the dealer says it still tests out ok and they won't replace it. It's like they want me to let my wife get in a tight spot with a dead battery before they'll replace it. This is the opposite of why a family owns a jeep in the first place.What’s the alternator issue? Haven’t heard of that yet….
With my bad battery adventure, I did some measurements to ensure everything was working right. Mine was putting out 14.7 volts when idling. Just a frame of reference.I don't recall the specs mentioned but when I took mine in the service tech mentioned the alternators in these 392 application are under-rated and that this is why the batteries don't last long even being AGM's. Wish o recalled more info. I'm on our second battery on one jeep and only 12k miles on her. The wife's has 18k and without using a tender every night, it only goes a few days before it barely turns over. But when I bring it in, the dealer says it still tests out ok and they won't replace it. It's like they want me to let my wife get in a tight spot with a dead battery before they'll replace it. This is the opposite of why a family owns a jeep in the first place.
Since the dealer in 20 miles away, the battery ends up getting sufficiently charged on the drive there to pass their "test".
Purgatory. Limbo. Silly.
Sent these guys a RFQ for two alternators, will report back. Thank you!There is a way to deal with the alternator. Marco (ovrlndx) suggest this place does a beautiful job, they can use the OEM housing and make a nice setup for you:
Video is here:
Factory Alternator is 220 AmpI don't recall the specs mentioned but when I took mine in the service tech mentioned the alternators in these 392 application are under-rated and that this is why the batteries don't last long even being AGM's. Wish o recalled more info. I'm on our second battery on one jeep and only 12k miles on her. The wife's has 18k and without using a tender every night, it only goes a few days before it barely turns over. But when I bring it in, the dealer says it still tests out ok and they won't replace it. It's like they want me to let my wife get in a tight spot with a dead battery before they'll replace it. This is the opposite of why a family owns a jeep in the first place.
