My first ever oil change and takeaways
Equivalent full synthetic SAE 0W-40 engine oil can be used but
must have the API Donut trademark.
May I add to that, per my 2024 Owner's Manual the oil MUST also say MS-A0921 on the back as seen in your picture.
There is some chatter out there that the larger filters will hit the frame when the engine torque causes the engine to twist? Has anybody observed that? I'm getting ready to order every thing for my first change and like the idea of the 041 SRT filter, but might back up on that if this is likely?
5th oil change at 17.5K miles, 3.5k in 6 months. Much cleaner this time with the bag to catch the oil while unscrewing the oil filter.
5th oil change at 17.5K miles, 3.5k in 6 months. Much cleaner this time with the bag to catch the oil while unscrewing the oil filter. View attachment 36022
Genius🙌, I’m totally doing this next oil change thanks for posting. I have been using old plastic shopping bags and it usually ends up spilling at one of the ends. The zip lock bags are a lot better to handle. 👍😉
Absolutely. It's not a zip lock bag but something very similar. I put an old t-shirt there to absorb the oil in case the bag is broken. It basically stood there upright and when the drip become very minimal I just remove the oil filter completely and it dropped into the bag.
6th oil change at 19808 miles with 61% oil life. The ziploc trick worked like a charm again when unscrewing the old oil filter, zero drop on the Fox ATS SS.
