Huge NoLimitz Feature Release (Beta)
Regarding the Tazer and NoLimitz on a 25 392. I installed the Tazer JL Mini that I had on a 2020 and 2023 Rubicon with firmware 11.4.5 and noticed the option to program the cruise buttons for the lockers, in particular the front locker only was not available. Neither was the rear brake lock on a turn. I ran it like that for a couple weeks and it worked well including the force 2wd. I purchased a NoLimitz, updated the Tazer to 11.4.7 and had issues trying to communicate with the NL. I also could not get the NL to communicate with the Jeep. I returned it and when they had the release sale I picked up another NL. I did get it to communicate and only set the top speed and torque settings as to not waste time in case something happened. I'm recovering from rotator cuff surgery and didn't drive it for a couple weeks, when I started it I immediately got a CEL and could not get it to clear. I removed the NL and the CEL went away. The Tazer is still operating as it has, still missing the 2 features I really used.
I did email Zauto and am waiting their usual 3 to 4 business days for them to get back to me. Anyone else have similar issues? I did update the NL firmware but am not looking forward to taking the dash apart again to see it fail.
I actually just installed my NoLimitz, I too had returned the original one when members were posting their horror stories about dead batteries, christmas tree dashboards and other issues. Really all I wanted it to do is MDS off and RFBLK, so now at least I have one.
I too bought another when the sale fired off and just a few minutes ago updated it to the new 24.1.8 just to see if the RFBLK option would pop up, it didn't. Now for what its worth, I have MDS off, Top speed set to 120 and IsTuned was on from ZAutomotive, I left this alone. I also didni't see Tamper Detection in the menu either. So far knock on wood, everything is working.
The update procedure and reading current NoLimitz firmware is still really buggy. They need to clean that us as well.
Istuned: On or Off (If your PCM has been unlocked or replaced, prevents dreaded P1400 code) NoLimtz must be installed and Istuned turned on prior to installing new PCM)
Also there is new Firmware available
Interesting, it is set to on as a default from ZAutomotive, I like the new canbus EVIC check but I guess if you originally hooked it wrong in the first place you really knew it when the dashboard lite up like a christmas tree or you jeep no longer started, lol
Did you enter the default Security Code? I think (not sure) you have to enter the code because the RFBLK is in the submenu of the Security system.
Security: Set + to enter code (The Default code is Set +, Set -, RES, Canc)
I didn't notice, I wonder if my IsTuned is also on which would cause the CELs. Have to reinstall and check that.
I tried that but it never went into the sub menu, sent Zautomotive an email to see what they say, thx for the tip though
Were you able to get to the RFBLK Screen did you just go to the security and then enter Set+, Set-, RES, Canc and did it just pop up? thx
They moved it inside the security section. Have to enter the code then scroll down to get to it.
I just scrolled past it as I wasn't going to make changes. It is to be nice tomorrow, I'll reinstall it then and see what happens.
I haven't updated firmware yet and am going to wait to do that. I unhooked my battery over the weekend, and after hooking back up the NoLimitz isn't activated. Can someone please remind me of the activation sequence for last firmware?
Just update the firmware and it's ready to go. Activation (turning on/off) is no longer required.
I'm not updating the firmware, staying on the prior for now. Do you remember how to "turn on" the module?
I believe you hold the left arrow on the left side of the steering wheel and turn on the ignition. You should have the emergency blinkers operate 5 times to confirm.
Thanks so much, will give it a try. If I can't get it turned back on, I'll just remove and update.
Attached it the 24.1.7 user's guide
Thank you! I was wrong, it's not this firmware either. Whatever was the last firmware before they updated to the new navigation/options.
It's all good, I just did a little internet searching and found what I needed. @BarneyM was right about the left arrow activation.
Just a reminder that the cruise control has to be turned off or you will still have a speed limiter. This is not mentioned in the instructions.
Ok got it figured out, my RES button seems a bit flakey, I tried it again watching very carefully an notice it wasn't registering then it would quickly time out and disappeared and back to the audio menu.
I exercised it about 20 to 30 times then went back and tried it again and just as many said into the sub menu it went. For what its worth the RFBLK feature is defaulted on along with brake lock. So if you just install the unit your at least protected without having to do anything with the RF Hub issue.
At this point I am not sure if the RES button is bad or what, I will need to follow up on that, least the Nolimitz seems to be functioning correctly on the latest firmware 24.1.8.
