Update-return from dealer.
I’m going to just post the text from the paperwork. The service writer provided to me. My understanding is that they did replace a module and an oxygen sensor, but the real issue was a simple as crimped wires that got pinched on the passenger seat slide rail.
4797 CHECK FOR NO START, FOUND WILL NOT TURN ON.
TOW INTO SHOP AND HOOK UP SCAN TOOL, FOUND NUMEROUS CODES FOR NO COMMUNICATION ACCESS STAR CONNECTORS AND DISCONNECT EACH MODULE ONE BY ONE, FOUND THAT THE
OCM MODULE CIRCUIT IS TAKING DOWN THE BUS SYSTEM. DISCONNECT THE OCM MODULE BUT CONDITION IS STILL PRESENT.
TRACE WIRING AND FOUND BUS WIRES WERE PINCHED BY THE PASSENGER SEAT TRACK. REMOVE PASSENGER SEAT TO. ACCESS WIRING AND REPAIR PINCHED WIRES WIRES WERE PINCHED. REROUTE WIRING HARNESS TO AVOID CONTACT WITH SÉAT TRACK. INSTALL SEAT AND CLEAR ALL CODES. CHECK OPERATION AND FOUND BUS SYSTEM IS NOW COMMUNICATING.”
