- Nov 16, 2022
- 1,568
- 3,106
- Current Rides
- 2023 Rubicon 392 20th Anniversary Edition, 1996 M1078 rolling fortress
Despite what the dealer fed you, it's not really possible to smell coolant without a leak, at least not for long. The coolant is going somewhere. There is only three way the coolant can go..... into the oil, into the exhaust, (both of these usually mean cracked head or failed head gasket) or more likely it's leaking out to the atmosphere/ground. You can check the oil to see if it's milky or smells like coolant at all. You can also give the exhaust a sniff to see if you think it's getting into the exhaust.I'm about 38K miles on this 2021. Noticed on recent trip that coolant was slightly below minimum line on the reservoir. Watched temps, and I never went above 220 on a day of offroad, and a day of highway driving. 210 to 215 the average, but I did see 219/220. Strong coolant smell from vents in vehicle, ie when running heat. Visual inspection showed no apparent leaks at the tank seam or hoses/connections. FWIW, there was a very distinct sloshing noise behind the dash, which I understand is heater core air/fluid interacting.
Brought to my dealer. A day later, service advisor states that they pressure tested over night, and again the following morning after getting the engine hot. Never lost pressure, zero pressure loss. Was told they topped up the coolant. Quick inspection on my way out from dealer - clean work, still no evidence of leaks around tank/hose/connection. The level was higher, right between min and max. Ran the heat on the way home, still getting a massive coolant smell. This morning, the coolant level is back just below minimum, but still not seeing evidence of leak. Service advisor tried to explain something about - natural loss over time, air in the system, can cause odor with no "leak." Is that true? I bought mopar coolant , will top up tonight. Maybe the system still has air, and needs burping...ie maybe their top up didn't get me to full/full (?). Might change the cap that folks are describing as culprit...though not seeing indicators that mine is 'bad.' What are indicators of bad cap?
Thanks for any insights.
If the leak is slow, and you keep driving, then it's really hard to locate, and the air moving through the engine bay can send a drop of coolant all over the place.
I would run it up to temp, and let it sit, running, in the driveway with the A/C off for 15 minutes or so, then go look for drips. If there are none, I'd shut it down and let it cool, then do it a few more times up to temp, and then cooling it down. If that fails, you can try the old UV dye in the coolant trick. I've never had much luck with the dye as it just gets everywhere making it impossible to tell where it's actually coming from, but it would confirm that there is indeed a leak.
My initial thought is that if there is no sign of coolant in the engine bay... maybe the heater core? A few drops of coolant mixed in with A/C condensate might be hard to notice.
You could also break out the old parts shotgun and throw a new cap and expansion tank on it as a preventative measure since we know those are prone to fail.
Good luck.
