That’s honestly comforting. Hoping my coolant adventures might be over.Sorry, smell outside the Jeep will never go away. Really is bad in the garage after a full engine heat cycle.
Well, I can tell you that it drove me crazy…. I looked for leaks thinking there has to be one with how bad it smells! But never needed to add any coolant for years. It does take a while to get all air out, so don’t be worried with adding a few ounces of coolant 3 or 4 times in the first 1000 miles…. It finally stays at the full line and then you can ignore it.That’s honestly comforting. Hoping my coolant adventures might be over.
For @AUSTX or others, if I had head-gasket issues - would I necessarily be seeing evidence of oil/coolant mix or loss of oil pressure? Or could a gasket failure be limited to loss of coolant, and not affecting/interacting with oil flow?
It sounds like you have a very small leak but not likely from the head gasket given no fluids mixing. Even a tiny leak can result in a significant loss of any fluid. Once it's fixed, given the powerful binding properties of glycol, I would recommend you wash your engine bay well using a citrus solvent and let it soak for about 10-15 min. Use brushes to get into nooks and crannies. Be sure to cover electrical. I've used Chemical Guys and Simple Green with very good results. Hope it turns out better than worse.That’s honestly comforting. Hoping my coolant adventures might be over.
Thanks !It sounds like you have a very small leak but not likely from the head gasket given no fluids mixing. Even a tiny leak can result in a significant loss of any fluid. Once it's fixed, given the powerful the binding properties of glycol, I would recommend you wash your engine bay well using a citrus solvent and let it soak for about 10-15 min. Use brushes to get into nooks and crannies. Be sure to cover electrical. I've used Chemical Guys and Simple Green with very good results. Hope it turns out better than worse.![]()
Taste it if coolant it should have a sweet taste to it. That’s why animals like it ,but it’s poisonous.I noticed a coolant smell yesterday. I stopped at Costco, opened the door and could smell coolant. I got home and looked under the hood. I could see splatter on the rod coming off the steering wheel, looked like dried liquid, and I could see dried liquid under the coolant tank. Must be leaking. I'll have to take it back to the dealer and have them check it.
It's Pink lolTaste it if coolant it should have a sweet taste to it. That’s why animals like it ,but it’s poisonous.
Smell it first could be mouse pee![]()
Let us know when you get it sorted out thanksIt's Pink lol
