Check it outMishimoto just released a larger all aluminum radiator for the Eco Diesel JL, I’m hoping one isn’t too far behind for the 392.
Is that hose from Napa or Amazon?go the replacement part in and swapped on the silicone hose, hopefully ill never have to use it.
(yes I know the logo is upside down, no I cant swap it around its on there too tightly, yes its going to bug me for the rest of time)
amazonIs that hose from Napa or Amazon?
Thanksamazon
Just my two cents: I ran two Mishimoto radiators on my JK over the years. They look fantastic and feel very well built, but both eventually developed leaks, and they didn't drop my coolant temps at all—no real cooling improvement.Check it outView attachment 52465
It’s not a head gasket issue. That is a braided coolant hose which should easily handle the pressure. What has most likely happened is when the manufacturer formed this hose into such a tight 90, they didn’t jam it onto the forming pin far enough. The inside of that curve should look like it’s bunched up or wrinkled, otherwise, the outer diameter hose wall will not have enough material and will be thin and stressed to the point of rupture. A common problem with formed hoses.about 27, 500miles on it. repair the 1st time was 250 last week. hose was replaced with OEM parts and bust yesterday evening back in the shop last night this morning they say its the same hose and to think about the head gasket. IDK
I really think it’s because it goes from 5/8 to 3/8 and it’s a 90 really choking the flow . I replaced mine at 12 k both looks good inside .just my two cents.It’s not a head gasket issue. That is a braided coolant hose which should easily handle the pressure. What has most likely happened is when the manufacturer formed this hose into such a tight 90, they didn’t jam it onto the forming pin far enough. The inside of that curve should look like it’s bunched up or wrinkled, otherwise, the outer diameter hose wall will not have enough material and will be thin and stressed to the point of rupture. A common problem with formed hoses.
Nice find… good replacement option![]()
Silicone Oil Cooler Hose, Black, fits Jeep Wrangler JL 392 2021+
The factory oil cooler hose on the 2021+ Jeep Wrangler JL Rubicon 392 cracks and collapses at the bend - the OEM rubber cracks and fails under the repeated heat cycling the 392 V8 generates in trail and low-speed use, splitting at the point of greatest flex. The Mishimoto Silicone Oil Cooler...www.mishimoto.com
saw this today, Ill be buying one as a trail spare.
Good idea. Just purchased one for a backup.![]()
that is a good point, once i get the hose in ill try and find some on the zamazon and share once foundThe only concern I have is the change in hose clamps. Constant tension clamps (the OEM original) are better suited for coolant hoses than the worm screw type included with the silicone hose.
Everything Mishimoto is premium quality, I have been using their Silicone hose on my H2 Hummer for nearly 15 years, they look as good as the day I put them on. I am absolutely sure this would be far better then the Mopar replacement hose (that has been updated at least 3 times so far)![]()
And the price of a full set of hoses ?I accidently duplicated my order and while calling to cancel the duplicate i told the rep that a full hose kit would be nice, and with a replacement bridge price too out of metal (the plastic that bolts on top of the radiator)
A full hose set would be really nice, and prob the only vehicle I've owned where it prob would be a major benefit/upgrade.
