2024 Jeep Wrangler 392 Final Edition is limited to 3,700 units
    Featured
March 19, 2024 , Auburn Hills, Mich. - The Jeep® Wrangler 392 - the quickest and most powerful Wrangler yet - is roaring off into the sunset with a special, limited-production Final Edition.
Powered by a 6.4-liter V-8, rated at 470 horsepower and 470 pound-feet of torque, Jeep Wrangler Rubicon 392 has ruled atop the Wrangler lineup thanks to its unique set of skills – it can rocket from 0-60 mph in 4.5 seconds and cover the quarter mile in 13.0 seconds, while also offering a 48:1 crawl ratio – all with a factory-backed warranty.
“Jeep Wrangler 392 remains atop the mountain in terms of all-out performance, power and unmatched capability. These are game-changing strengths that our most impassioned Jeep enthusiasts asked us for, and that the competition was unable to match," said Bill Peffer, senior vice president and head of Jeep brand – North America. “To celebrate the existence of this powerhouse, we’re sending the raucous, 392-powered Wrangler off in style with this special Final Edition, limited to just 3,700 units globally.”
Jeep Wrangler 392 Rubicon Final Edition
The 2024 Jeep Wrangler 392 Rubicon Final Edition is immediately recognized by unique Final Edition hood and front fender vent decals and, via the standard Xtreme 35 Package, bronze 17-inch beadlock-capable wheels wrapped in 35-inch BFGoodrich all-terrain tires.
Additional standard exterior equipment on Wrangler 392 Rubicon Final Edition include:
  • Factory-installed 8,000-pound-capacity Warn winch
  • Mopar triple loop grille guard
  • Mopar heavy-duty rock sliders
  • Half-inch suspension lift delivering:
    • 34.5 inches water fording (+ 0.5 inch)
    • 11.6 inches ground clearance (+ 0.5 inch)
For the 2024 model year, all Jeep Wrangler models receive enhancements, including a new iconic seven-slot grille, standard side curtain air bags, a 12.3-inch Uconnect touchscreen radio and more.
Black Nappa leather, 12-way power performance seats, new Mayan gold stitching and Tupelo highlights throughout the cabin are unique to the 2024 Jeep Wrangler 392 Rubicon Final Edition. A special shifter medallion and swing gate plaque denote the 392 Final Edition’s special, high-powered place in Wrangler’s 80-plus year history. A Mopar fold-out swing gate table and Mopar Jeep 83-piece toolkit are standard, with a Mopar on-board air compressor optional for trailside tire pressure management.
Production of the 2024 Jeep Wrangler 392 Rubicon Final Edition will be limited globally to 3,700 units; 3,300 for the U.S., 300 for Canada and 100 for rest of the world. The U.S. MSRP is $99,995 (excluding $1,895 destination) and is open for order now at Jeep dealers. Production commences in the second quarter at the Toledo (U.S.) Assembly Plant.
The most capable, quickest, most powerful Wrangler, Jeep Wrangler Rubicon 392 is powered by a 6.4-liter V-8, rated at 470 horsepower and 470 pound-feet of torque. Mated to the crisp-shifting TorqueFlite eight-speed automatic transmission and Selec-Trac full-time active transfer case, the V-8 rockets the Jeep Wrangler Rubicon 392 from 0-60 mph in 4.5 seconds and the quarter mile in 13.0 seconds.
The 6.4-liter is critical to on- and off-road performance: nearly 75% of the Wrangler Rubicon 392’s peak torque is available just above engine idle speed; this delivers exciting performance, whether enabling that fast 0-60 mph time or crawling up steep grades.
Jeep engineers ensured the Wrangler Rubicon 392’s V-8 gets fresh air, regardless of the terrain and weather. The Hydro-Guidea air intake system includes a tri-level ducting system with a series of drains, including a one-way drain in the air box that separates water – up to 15 gallons per minute – away from the engine’s incoming air.
An active dual-mode exhaust is standard to deliver an exhilarating and unmistakable sound. The system engages automatically, opening valves in the exhaust system, under higher engine loads to reduce exhaust back pressure. The driver can also activate the system with the press of a button. The dual-pipe performance exhaust system is finished off with unique quad exhaust tailpipes.
A high-torque capacity TorqueFlite 8HP75 eight-speed automatic transmission delivers quick, crisp gear changes during both normal and performance driving conditions. This transmission also enables the driver to change gears via the new steering wheel-mounted aluminum paddle shifters, a first for the Jeep Wrangler, or the Electronic Range Select shifter.
The heart of the driveline is a Selec-Trac full-time, active transfer case with a 2.72 low-range gear ratio. The transfer case has four driver-selectable modes: 4WD Auto, 4WD High, Neutral and 4WD Low. This full-time two-speed transfer case is intuitive and allows the driver to set it and forget it, while constantly sending power to the front and rear wheels. The Selec-Trac transfer case also allows for Wrangler Rubicon 392 to be flat-towed.
Off road, the Wrangler Rubicon 392 delivers the legendary capability Jeep is renowned for. This includes Off-road Plus with Sand and Rock modes: The push of a button maximizes the Jeep Wrangler Rubicon 392’s tractive capabilities. The modes adjust throttle, transmission shift points and traction control for peak performance on higher speed passes on sand terrain, as well as during low-speed rock crawling. The Off-road Plus drive mode also gives drivers the ability to lock the rear axle at high speeds while in 4H.
Selec-Speed Control manages vehicle speed in 4L while traversing off-road terrain without requiring throttle or brake input. Selec-Speed Control is activated using a button on the dashboard and can be adjusted from 0.6 mph - 5 mph simply by using the Electronic Range Select shift control.
The Wrangler Rubicon 392 masters low-speed downhill descents by using the 6.4-liter V-8’s engine braking, revised transmission torque converter lockup control and a 48:1 crawl ratio to manage vehicle speed without the driver needing to use the brake pedal.
The Jeep Wrangler Rubicon 392 chassis includes upgraded frame rails, front upper control arms and cast-iron steering knuckles to take full advantage of the Wrangler Rubicon 392’s power and torque. Heavy-duty brakes bring the Wrangler Rubicon 392 to a composed stop no matter the terrain.
The Wrangler Rubicon 392’s off-road prowess flows from wide track, heavy-duty Dana 44 front and rear axles with thicker axle tubes and Tru-Lok electronic locking differentials. An electronic front sway-bar disconnect maximizes suspension travel for the most demanding off-road conditions.
For 2024, new standard equipment on Wrangler 392 includes:
  • Xtreme 35 Tire Package
  • Acoustic front glass, thicker carpet and additional sound deadening foam
  • Heated seats and steering wheel
  • Integrated front off-road camera
  • 12-way power adjustable front seats
Jeep Wave
Jeep Wave is a premium owner loyalty program filled with exciting benefits and perks, including worry-free maintenance at no additional cost. Jeep Wave was created to bring our owners steadfast care and dedicated 24/7 support. All Jeep brand vehicles and trims, including all trims of the 2024 Jeep Wrangler, are automatically enrolled upon purchase.
Jeep Brand
Built on more than 80 years of legendary heritage, Jeep® is the authentic SUV brand that delivers legendary off-road capability, interior refinement, high-tech features and versatility to people who seek extraordinary journeys. The Jeep brand delivers an open invitation to live life to the fullest by offering a broad portfolio of vehicles that continues to provide owners with a sense of safety and security to handle any journey with confidence. Jeep Wave, a premium owner loyalty and customer care program that is available to the entire Jeep 4x4 lineup, is filled with benefits and exclusive perks to deliver Jeep brand owners the utmost care and dedicated 24/7 support. The legendary Jeep brand's off-road capability is enhanced by a global electrification initiative that is transforming 4xe into the new 4x4 in pursuit of the brand’s vision of accomplishing Zero Emission Freedom and added 4x4 capability. All Jeep brand vehicles will offer an electrified variant by 2025.
Hey Dral97,
I have outlined stripes I purchased right after I bought my rig in Oct '22 from Brendan at L&B Design works. Got the hood, vent, and tailgate also. They have held up perfectly.
Thing is...they are layers of striping...so you'd apply the wider base layer that is bronze then put the black layer over it. After that, add the 392 decal where you like it along the stripe. Would have to find a thin bronze to lay around your black and order the "392" decal. I'd check in with Brendan. Might be worth removing your black decal and starting fresh. They decals are very high quality and affordable.
That looks great! Thanks for the info!
Hemi V8’s are done for Mopar / Stellantis. I think the Final Edition title would also indicate they’re done. Just like the Final Edition Ram TRX which ended the 6.2L hellcat in that platform.
With one exception - the truck version of the 6.4 will continue on in 2025 in the Ram 2500/3500 HD pickups and 4500/5500 chassis-cabs. Stellantis confirmed this a few weeks ago. All other cars and trucks and versions of the Hemi will be gone by the end of 2024.
Only because emissions standards currently allow for it. I bet that’s a short term solution for them. They seem all in on turbo 6cyl and electrification on everything else.
I don't know. Ford has the Ecoboost in the F150, but not the F250 or F350. GM has the TurboMax in the 1500 but not the 2500 or 3500. Ram is following suit by putting the Hurricane 6 in the Ram 1500 but not the 2500 or 3500. HD truck buyers want an alternative to diesel (cheaper truck, cheaper fuel, cheaper maintenance) that's a gas V8 not a gas turbo 6. Also, the fuel economy and emissions standards for HD trucks are different. If we're talking 10 years from now you're probably right, but not in the next 2-3 years.
Short term means 2-3 years. Stellantis isn’t Ford or Chevy. Both plan to continue to offer a V8 as an option on their half ton trucks. Ford is still cranking out V8 powered Mustangs and Chevy also continued with the Corvette. Stellantis doesn’t seem to really care what buyers want… the future Dodge Charger and the non selling Hornet are both great examples. If they can figure a way to throw something more “efficient” in the HD trucks other than a V8 they will. Regardless …back to the thread the V8 Wrangler is certainly dead. That dirt road cred video mentioned a Hurricane 500 AEV Wrangler.
Just got my 2024 392 in February and absolutely love it. A FE would be nice but I’m happy with mine. Too bad it’s the end of an era. For anyone interested, we just returned from a 2700 mile road trip and averaged 16.6 mpg for the trip! That included some high speed rips.
Are you sure you have a 392? 😄. I drove mine 6 1/2 hours on the highway, anywhere from 55 to 75 mph, and I averaged about 9.8 for that trip. lol. Good for you. That’s pretty darn good. Wish I got that kind of gas mileage. And congrats on your 24. I love mine as well, right down to the red seats. Enjoy!
How long did it take…from initial order to receiving it?
I was saying that sarcastically. There’s very little difference between the 2024 and FE except some decals and a couple other things that can be purchased from factory or aftermarket. I had just put some decals from L&B on my 2024 that coincidentally looked like the FE decals. I don’t think anyone has taken possession of a FE, especially when I originally posted which was days after the FE announcement
So, Just ordered a 2024 Final Edition in Tuscadero Pink...It's so new that on the Jeep Order Tracking website, it has a pic but no wheels are on it...The brake rotors show inside the tires lol, also no triple hoop installed in the pic. I am big dude, but got to tell you, that pink will be ridicules and I don't care who says what. Limited color on a limited model = allot less loss, maybe lol....
Maybe the wheels will be different on the Final Edition?
I think I read they are supposed to be bronze, but then again so are the 2024, just a lighter bronze-silver. In the illustration at the beginning they are almost like the dodge brass monkey shade…
That’s a good looking Jeep! :)
Nice looking Jeep! Like the decals. As for the actual Final Edition models, it looks like they haven’t begun producing them yet. Anyone have an idea when that may begin?
Find anything out yet? I too am itching to know but didn't want to start a new post for that just yet. Placed an order for a white FE on 18APR, disappointed there wasn't a green or orange available but white/black/bronze accents looks good.
By the Jeep inventory tool, it’s still appears that the final editions have not yet gone into production. I have no idea how accurate that tool is. But I can’t argue with you about the weight looking good with the black and bronze accents. It’s my favorite color. 😃
Looks like the first Final Edition unit is on its way to the dealership.
Unfortunately my build tracker still only says TBD. I'm happy to have a tracker vs nothing but of course right now it's just a tease:
So the Jeep Website only shows Dealer ordered units for inventory not Sold Orders that we as customers order. The tracker is our device to track. I’m in the same boat, ordered 12 Apr but no movement. Was told that Sold Orders have priority but that is just another ruse being told…Seems orders get built as it best fits the manufacturers schedule without regard to date ordered or VIN sequence. Even the dealers reps can’t explain. I really want to see what the new wheels and seats actually look like.
On the Jeep website you can build Final Editions now (whether or not you can still order them). But if you click inside the interior you can get a good idea of what the black seats with bronze stitching looks like. It was also interesting seeing the one touch roof closed or open.
