2024 Jeep Wrangler 392 Final Edition is limited to 3,700 units
    Featured
March 19, 2024 , Auburn Hills, Mich. - The Jeep® Wrangler 392 - the quickest and most powerful Wrangler yet - is roaring off into the sunset with a special, limited-production Final Edition.
Powered by a 6.4-liter V-8, rated at 470 horsepower and 470 pound-feet of torque, Jeep Wrangler Rubicon 392 has ruled atop the Wrangler lineup thanks to its unique set of skills – it can rocket from 0-60 mph in 4.5 seconds and cover the quarter mile in 13.0 seconds, while also offering a 48:1 crawl ratio – all with a factory-backed warranty.
“Jeep Wrangler 392 remains atop the mountain in terms of all-out performance, power and unmatched capability. These are game-changing strengths that our most impassioned Jeep enthusiasts asked us for, and that the competition was unable to match," said Bill Peffer, senior vice president and head of Jeep brand – North America. “To celebrate the existence of this powerhouse, we’re sending the raucous, 392-powered Wrangler off in style with this special Final Edition, limited to just 3,700 units globally.”
Jeep Wrangler 392 Rubicon Final Edition
The 2024 Jeep Wrangler 392 Rubicon Final Edition is immediately recognized by unique Final Edition hood and front fender vent decals and, via the standard Xtreme 35 Package, bronze 17-inch beadlock-capable wheels wrapped in 35-inch BFGoodrich all-terrain tires.
Additional standard exterior equipment on Wrangler 392 Rubicon Final Edition include:
  • Factory-installed 8,000-pound-capacity Warn winch
  • Mopar triple loop grille guard
  • Mopar heavy-duty rock sliders
  • Half-inch suspension lift delivering:
    • 34.5 inches water fording (+ 0.5 inch)
    • 11.6 inches ground clearance (+ 0.5 inch)
For the 2024 model year, all Jeep Wrangler models receive enhancements, including a new iconic seven-slot grille, standard side curtain air bags, a 12.3-inch Uconnect touchscreen radio and more.
Black Nappa leather, 12-way power performance seats, new Mayan gold stitching and Tupelo highlights throughout the cabin are unique to the 2024 Jeep Wrangler 392 Rubicon Final Edition. A special shifter medallion and swing gate plaque denote the 392 Final Edition’s special, high-powered place in Wrangler’s 80-plus year history. A Mopar fold-out swing gate table and Mopar Jeep 83-piece toolkit are standard, with a Mopar on-board air compressor optional for trailside tire pressure management.
Production of the 2024 Jeep Wrangler 392 Rubicon Final Edition will be limited globally to 3,700 units; 3,300 for the U.S., 300 for Canada and 100 for rest of the world. The U.S. MSRP is $99,995 (excluding $1,895 destination) and is open for order now at Jeep dealers. Production commences in the second quarter at the Toledo (U.S.) Assembly Plant.
The most capable, quickest, most powerful Wrangler, Jeep Wrangler Rubicon 392 is powered by a 6.4-liter V-8, rated at 470 horsepower and 470 pound-feet of torque. Mated to the crisp-shifting TorqueFlite eight-speed automatic transmission and Selec-Trac full-time active transfer case, the V-8 rockets the Jeep Wrangler Rubicon 392 from 0-60 mph in 4.5 seconds and the quarter mile in 13.0 seconds.
The 6.4-liter is critical to on- and off-road performance: nearly 75% of the Wrangler Rubicon 392’s peak torque is available just above engine idle speed; this delivers exciting performance, whether enabling that fast 0-60 mph time or crawling up steep grades.
Jeep engineers ensured the Wrangler Rubicon 392’s V-8 gets fresh air, regardless of the terrain and weather. The Hydro-Guidea air intake system includes a tri-level ducting system with a series of drains, including a one-way drain in the air box that separates water – up to 15 gallons per minute – away from the engine’s incoming air.
An active dual-mode exhaust is standard to deliver an exhilarating and unmistakable sound. The system engages automatically, opening valves in the exhaust system, under higher engine loads to reduce exhaust back pressure. The driver can also activate the system with the press of a button. The dual-pipe performance exhaust system is finished off with unique quad exhaust tailpipes.
A high-torque capacity TorqueFlite 8HP75 eight-speed automatic transmission delivers quick, crisp gear changes during both normal and performance driving conditions. This transmission also enables the driver to change gears via the new steering wheel-mounted aluminum paddle shifters, a first for the Jeep Wrangler, or the Electronic Range Select shifter.
The heart of the driveline is a Selec-Trac full-time, active transfer case with a 2.72 low-range gear ratio. The transfer case has four driver-selectable modes: 4WD Auto, 4WD High, Neutral and 4WD Low. This full-time two-speed transfer case is intuitive and allows the driver to set it and forget it, while constantly sending power to the front and rear wheels. The Selec-Trac transfer case also allows for Wrangler Rubicon 392 to be flat-towed.
Off road, the Wrangler Rubicon 392 delivers the legendary capability Jeep is renowned for. This includes Off-road Plus with Sand and Rock modes: The push of a button maximizes the Jeep Wrangler Rubicon 392’s tractive capabilities. The modes adjust throttle, transmission shift points and traction control for peak performance on higher speed passes on sand terrain, as well as during low-speed rock crawling. The Off-road Plus drive mode also gives drivers the ability to lock the rear axle at high speeds while in 4H.
Selec-Speed Control manages vehicle speed in 4L while traversing off-road terrain without requiring throttle or brake input. Selec-Speed Control is activated using a button on the dashboard and can be adjusted from 0.6 mph - 5 mph simply by using the Electronic Range Select shift control.
The Wrangler Rubicon 392 masters low-speed downhill descents by using the 6.4-liter V-8’s engine braking, revised transmission torque converter lockup control and a 48:1 crawl ratio to manage vehicle speed without the driver needing to use the brake pedal.
The Jeep Wrangler Rubicon 392 chassis includes upgraded frame rails, front upper control arms and cast-iron steering knuckles to take full advantage of the Wrangler Rubicon 392’s power and torque. Heavy-duty brakes bring the Wrangler Rubicon 392 to a composed stop no matter the terrain.
The Wrangler Rubicon 392’s off-road prowess flows from wide track, heavy-duty Dana 44 front and rear axles with thicker axle tubes and Tru-Lok electronic locking differentials. An electronic front sway-bar disconnect maximizes suspension travel for the most demanding off-road conditions.
For 2024, new standard equipment on Wrangler 392 includes:
  • Xtreme 35 Tire Package
  • Acoustic front glass, thicker carpet and additional sound deadening foam
  • Heated seats and steering wheel
  • Integrated front off-road camera
  • 12-way power adjustable front seats
Jeep Wave
Jeep Wave is a premium owner loyalty program filled with exciting benefits and perks, including worry-free maintenance at no additional cost. Jeep Wave was created to bring our owners steadfast care and dedicated 24/7 support. All Jeep brand vehicles and trims, including all trims of the 2024 Jeep Wrangler, are automatically enrolled upon purchase.
Jeep Brand
Built on more than 80 years of legendary heritage, Jeep® is the authentic SUV brand that delivers legendary off-road capability, interior refinement, high-tech features and versatility to people who seek extraordinary journeys. The Jeep brand delivers an open invitation to live life to the fullest by offering a broad portfolio of vehicles that continues to provide owners with a sense of safety and security to handle any journey with confidence. Jeep Wave, a premium owner loyalty and customer care program that is available to the entire Jeep 4x4 lineup, is filled with benefits and exclusive perks to deliver Jeep brand owners the utmost care and dedicated 24/7 support. The legendary Jeep brand's off-road capability is enhanced by a global electrification initiative that is transforming 4xe into the new 4x4 in pursuit of the brand’s vision of accomplishing Zero Emission Freedom and added 4x4 capability. All Jeep brand vehicles will offer an electrified variant by 2025.
It wouldn't surprise me that once word got out, everyone on the fence went in and got their order in. The 20As were about that number and they were sold out in about a week or so iirc.
End of an (albeit short) era folks. Enjoy what we got. I just got off the phone with my dealer. Mine's going in this week to get some auxiliary lights installed. My build will pretty much be done at that point other than a few cosmetic things. (y)
Wouldn’t be to concerned about these selling out quickly.
Jeep Wave
Jeep Brand
I like it very much. If I could afford two 392’s I would buy one for fun. That red.
Not sure how that’s possible when the order banks just recently opened.
Yep…tongue in cheek. I thought that was obvious considering the inability to order one. My 2024 has decals and all the functions of FE…only better. I was pointing that out in a sarcastic manner. I don’t understand paying $8000 (plus $40-$50k in dealer add ons) for decals, an under powered compressor, an underpowered winch, and decals but I repeat myself. Text is bland like that.
I’m with you on that….mine just got shipped last week so hopefully April pickup from the dealer.
Where did you get the bronze striping? I have the upper body graphic as well and I like the way it looks with the bronze stripes around it.
Hey Dral97,
I have outlined stripes I purchased right after I bought my rig in Oct '22 from Brendan at L&B Design works. Got the hood, vent, and tailgate also. They have held up perfectly.
Thing is...they are layers of striping...so you'd apply the wider base layer that is bronze then put the black layer over it. After that, add the 392 decal where you like it along the stripe. Would have to find a thin bronze to lay around your black and order the "392" decal. I'd check in with Brendan. Might be worth removing your black decal and starting fresh. They decals are very high quality and affordable.
Not even the final edition that is already sold out?
I think it may be the opposite. Ordering a non Final Edition 392 may no longer be possible, but you can still get an FE.
But regardless, time is running out. Remember last year they closed the books on ordering a 2023 Wrangler on March 13 and they started taking orders for 2024s on April 26. This year will be a little later, with the cutover likely occurring in the May/June timeframe. But if you want one, don't wait.
The regular 392 (if you can call it regular) closed a few hours after the final edition opened last week.
Final edition is still available.
No, there is no fathom blue still - I'm beginning to thing that was a complete farce ... I wouldn't wait for it.
Wow. Just wow. Just saw a FE on a FB group. Underwhelming is the first thing that comes to mind. Absolutely ZERO stitching on the black seats. No Rubicon. No 392. Notta. Decal set just reworked from the 20A to say final edition. A little disc on the shifter that says FE. ::::: disappointed ::::::: this is how the final one is going out. 🫤
Are we all just assuming it’s the end of the 392. Or, is it just a final run of the current 392 configuration. It does appear to be pretty lame for a wrap up. Has JEEP come out with an official statement that they’ll no longer outfit a wrangler with a 392? I know it’s not a true indicator of anything, but they still brought a concept vehicle to the Easter event called the LowDown, featuring the 392. Please don’t rough me up for asking, I really don’t know. Any thoughts?
Hemi V8’s are done for Mopar / Stellantis. I think the Final Edition title would also indicate they’re done. Just like the Final Edition Ram TRX which ended the 6.2L hellcat in that platform.
Thanks for sharing. The now-gone 2024 392 red seats actually look more special imo.
Hi there, any other images posted on the FE interior? Dashboard trim? Do you have a link to the images? Thanks.
Those images were of the “concept” final edition and not the final production version. Here’s a vid from Dirt Road Cred showing more
I thought I saw on Dirt Road Cred that maybe this was a prototype? Perhaps not a production version? Not that I think 392 stitching on the seats would make much difference. Of course this could simply be a "whatever they have left" kind of special edition. Happy with my 23'XR
Yes the video is posted above your post
Thanks for posting the Vid 👍🏻👍🏻✌🏻✌🏻 I sure hope they’re correct with their guess that’s this is just a prototype!
