Brutus 392
I run mostly 93 , put 91 in it once didn't really notice a difference.
Premium only for Earl 392 . Yes 27 would be a great 400 mile range approximatelyi run 90 octane ethanol free at sheetz in our area. seams to run great. i also get slightly higher mpg about .5 mpg over running 93 and seams to cost about the same. i just wish our gas tank was more like 27 gallon instead of 21. i also have not found a good solution to a bigger tank.
91 and 10% Ethanol here in AZ.92 Octane here in WA. Will throw Ethanol free in any chance I see it.
Stand byIt is in the 392 manual
Ancient Thread, but I have similar thoughts. There are a number of options; ARB makes a underbody tank that ALLEGEDLY will fit under a 392, but… they don’t specifically catalog it, and it’s not cheap. but This APPEARS to be the most reasonable option; I would NOT keep fuel in it unless I was headed out into the boondocks.. https://titanfueltanks.com/4040487i run 90 octane ethanol free at sheetz in our area. seams to run great. i also get slightly higher mpg about .5 mpg over running 93 and seams to cost about the same. i just wish our gas tank was more like 27 gallon instead of 21. i also have not found a good solution to a bigger tank.
Do you have a link to arb tank?Ancient Thread, but I have similar thoughts. There are a number of options; ARB makes a underbody tank that ALLEGEDLY will fit under a 392, but… they don’t specifically catalog it, and it’s not cheap. but This APPEARS to be the most reasonable option; I would NOT keep fuel in it unless I was headed out into the boondocks.. https://titanfueltanks.com/4040487
That’s an additional 12 gallons - which should solve most range problems, IMHO. /cross fingers.
Took a little digging - found it. NOTE that it says it's only for the V6, but I read somewhere that it had been successfully installed into a 392. Not sure how much additional fabrication/hammering it took to make possible.Do you have a link to arb tank?![]()
This guy used a Long Range America system, had a shop do a custom exhaust for him. Here it is over on the JL Forum:Took a little digging - found it. NOTE that it says it's only for the V6, but I read somewhere that it had been successfully installed into a 392. Not sure how much additional fabrication/hammering it took to make possible.
Linky: http://thelongranger.com.au/jeep/wrangler/jl/petrol
The person that installed it - mentioned the expense of both the tank, not to mention shipping to the US from AU, and then getting it in. If you REALLY want range... another 40 or 70 liters (10 or 17 gallons) would help.
Long Range America Aux Fuel Tank installed on 392
The mpg/fuel situation for the 392 is not ideal. I drive all over the country and to the middle of nowhere, so the range anxiety I got up in the mountains watching my gauge rapidly decrease was not fun. I read a lot about extra fuel storage for the 392 and just did not like the idea of having...www.jlwranglerforums.com
It’s in the manual. Yours may have not come with one neighbor got a 24 had to down load it my 23 came with oneNormally if a vehicle requires higher octane it is listed. There is nothing at the fill or on the door, nothing on the visor, nothing on the dash by the fuel gauge.
Does anyone else have anything marked anywhere?
