What about the brakes?
The XR is the same physical brakes, but it has a "brake booster" that I believe is vacuum controlled.
That is what I heard also… from a guy… who knows a guy. 😉
I’m kidding. (Sorry for being sarcastic)
Actually all modern cars have brake boosters. All it does is amplify the force applied by your foot (via the big fat peddle) to what is actually applied to the Master Cylinder. So you push down with 50 lbs of force and the brake booster applies 170 lbs of force to the master cylinder. Generally most gasoline passenger vehicle use engine vacuum pressure to do this. They call this system “powered-assisted” brakes, but it’s the same thing.
All Wranglers have power assisted brakes. It is possible the Xtreme Recon uses a different one but I kinda doubt it (back to cost and parts supply efficiency). I could be totally wrong (I usually am 🤣) so if anyone has some part numbers or better info please chime in!
All I know is Scott Blum over on FB noted that the XR brakes were boosted over the non XR. No details were given on how that was achieved.
Yes, that's where I heard it too. Someone else created a list of the differences between standard and XR models, and the "brake booster" was listed on the XR. Who knows.
I would bet even aftermarket brake pads could make a difference, but I haven't found any that I want to try yet. LOL
Bringing this back up. Brake booster different? Should be a part number?
Also why would the sway bar links be different? And it seems an obscure part to mention being different, they are like $50. It is different than any other Rubicon. But no reason to be different from a 392 Rubicon.
You know I asked the guys when I was picking up a part at my local dealer. Both the parts manager and lead tech showed me in the computer system that ALL Jeep 392's use the same Brake Booster (Mopar Part# 68465215AA). The reason it requires that specific part for all 392's is that all 392's come Standard equipped with the Forward Collision Warning (FCW) with Mitigation. That means the brake system needs to be electronically controlled for FCW "active braking" (aka: brake by wire). It is also standard to that master cylinder, so that is the only part that fits the bill. It's also not unique to just the 392, other models use it.
It seems like there is a tendency to add xtra differences like this "boosted brakes" to the mystique of the Xtreme Recon package that just don't exist. In the end the XR is just what Jeep said it is: 4.56:1 gears, a lift kit with MOPAR shocks, 35" tires with 17x8 wheels + the tail gate and fender flares to keep it legal.... and bragging rights (if you think those are all improvements over the standard 392). Personally, I like bits of both the standard 392 and the 392XR. I like 35" tires and the 4.56:1 axel ratio on the 392XR. But I prefer the look of the original 392 rims/beadlocks, and the FOX shocks/standard lift components, and the price on the regular 392. But that's the cool thing about a Jeep, you can customize it to fit you.
I agree, I think there is a little overloading On the XR ingredients because it does more stuff on smaller engine levels. I am sure they add all that stuff to the willys. But I immediately questioned the list because of, funny enough, the sway bar link. There is absolutely no reason for them to be different on the 392XR. And would seem like a waste in the manufacturing process. They are different on every other XR, not the 392, same lift height, same sway bar link…
