Tazer JL Mini and DTC Codes
Good morning!
I recently purchased a Tazer JL Mini for my 2021 Jeep JL 392 so that I could adjust the tire size due to putting 37" tires on the Jeep. Everything worked flawlessly at first - speedo was correct with the adjustment I made using the Tazer JL Mini. However, about a week ago I received two DTC codes - the first one was U1514-87, and the second was U0415-00. I looked them up on the internet and it described them as:
BCM U1514-87 - "Engine Controller Secret Code-Missing Message"
ABS U0415-00 - "Invalid Data Received from Anti-Lock Brake System (ABS) Control Module
Regarding the BCM code - Secret Code???
I cleared the codes with the Tazer JL Mini and rebooted and followed the instructions to ensure I did not lose my settings. Went back into the menu to look at the DTC's and they had returned. I, then, turned the Jeep off and removed the negative battery cable for a couple of minutes. Reconnected the battery cable and restarted the Jeep. No "Check Engine" light, so I thought it was cleared. Turned the Jeep off and followed the instructions to, once again, check the DTC's...the two mentioned above were still there.
At that point I cleared the DTC's, reset the Jeep back to stock, removed the Tazer, and removed/reconnected the battery cable. Started the Jeep up and took it for a drive around the neighborhood. Got back to the house and, using an OBDII device for my Jeep, looked to see if there were any DTC's. There were none.
Is the Tazer faulty, because obviously - when it was installed - I received those two codes and now I am not?
Any ideas guys?
I didnt see this post in the thread originally. I get the exact same code about the secret code.
Remember that the two connections that you remove to install the tazer are what power the radio and the radio is a major part of the brain of the vehicle. Therefore, if you leave the tazer connected so you can do the live functions that codes like the secret thing are probably normal.
For the more important part.
I WENT TO GET MY SECOND KEY PROGRAMMED AND MY TECH ASKED ME IF I WAS SURE IF ALL MY LITTLE GADGETS WERE REMOVED FROM THE VEHICLE AND I SAID YES AND RIGHT BEFORE I GOT HERE I STOPPED AND CLEARED THE ENTIRE SYSTEM BEFORE I PULLED IN THE PARKING LOT. HE SAID OK BECAUSE IF I HOOK UP THAT COMPUTER AND THERE IS ANYTHING CONNECTED BIG BROTHER IS GOING TO KNOW AND I CANT REVERSE IT.
I SAID I DO HAVE ONE QUESTION, HOW COME I GET ALL THESE GOOFY CODES FOR NO REASON THAT MAKE NO SENSE,
HE SAID ITS REAL SIMPLE, IF THE CHECK ENGINE LIGHT DOESNT NOT COME ON AND THE JEEP IS RUNNING FINE AND NOT ACTING STRANGE IN ANY WAY JUST KEEP DRIVING.
HE SAID FOR MANY YEARS HE WOULD TRY TO CHASE EVERY CODE AND WHY DID IT COME ON AND SPENT HOURS SCRATCHING HIS HEAD FOR YEARS AND HE FINALLY LEARNED FROM HIS SENIOR TECHS AT THE TIME THAT IT IS A PHENOMINA THAT YOU ARE NEVER GOING TO FIGURE OUT AND NO ONE EVER HAS AND DONT WORRY ABOUT IT. BUT IN THE EVENT THAT HE IS ABLE TO EXPLAIN IT HE SHOULD GO GET A JOB MAKING TEN TIMES WHAT HE MAKES BEING A COMPUTER PROGRAMMER SENDING PEOPLE TO THE MOON.
HE SAIDS THE ROOKIES COME IN AND HE SEES THEM WITH THE COMPUTERS AND BOOKS AND ASKING OTHER TECHS WHATS UP WITH THIS AND HE TELLS THEM DONT GET HOOKED ON IT TRUST ME IGNORE IT THERE IS NO EXPLANATION.
TAZER OR NOT THE JEEP COMES UP WITH STRANGE CODES FOR NO REASON THAT ANYONE CAN EXPLAIN AND AS LONG AS NO CHECK ENGINE LIGHT AND NO ISSUE, KEEP DRIVING DRIVER.
I MUST SAY I HAVE OWNED MANY VEHICLES AND MANY OBD READERS AND NO OTHER CAR EVER THREW WEIRD CODES FOR NO REASON BUT I AM NOT GOING TO DRIVE MYSELF NUTS OVER IT EITHER AND NEITHER SHOULD YOU. KEEP DRIVING DRIVER, WE HAVE ONE OF THE BEST VEHICLES ON THE PLANET, THE POWER OF A SPORTS CAR WITH THE ROOM AND COMFORT OF AN SUV THAT CAN ALSO MAKE IT HOME IN A BLIZZARD OR TAKE THE RUBICON TRAIL IF THE REGULAR ROAD IS CLOSED FOR ANY REASON
I AM NOT YELLING I PUT IT IN CAPS TO GET PEOPLES ATTENTION TO READ BECAUSE ITS IMPORTANT.
Thank you for this. I had a gut feeling this was the case and not to worry unless check engine light comes on but it takes experience to know one way or another. I just installed my Tazer and checked codes just for the kick and then began the terror of “oh my god my overpriced V8 Jeep is breaking….” Lol
I was going to get a Tazer to do many things to my JT but not now.
