Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Thank you for your reply...if you don't mind can you discuss your width reasoning and your gear ratio / rpm / drivability experience?Dynatrac Pro Rock 60/80 Elite HD Custom Width 70.5, Gear Ration 5.38 on 40s
It's a tank, pun intended. It's definitely much bigger and heavier, still trying to get used to it. Thinking I should have gotten an LJ and built it for the Hammers instead of this monster but it's a toss up that's pretty close, both have good and bad points depending on the type of wheeling that you do. Horses for courses.......So after wheeling your built 392 for a while, how does it compare in rocks compared to shorter, lighter TJ?
Thanks for the pictures. If one of your pictures shows the ground point for the electric steering pump would mind pointing it out or circle it. Thanks you have so much more of your Jeep exposed than I do. I had my fender liner removed as it was torn when I received the Jeep. They sent me a new one. I replaced it b4 I knew about power steering overheating. Thanks again PS nice jobSome progress
Who is making these now? I had one on my TJ and CJ back in the dayNext project while waiting for bumpers and skids from Next Venture Motorsports. Not much room for anything in the engine compartment but will see if I can shoehorn this in there somewhere.
