Retractable running boards without door magnet
IronHorsePilot
New member
Missouri
2024 JLU 392
Hello all, I pick up my 392 Jeep monday and I the first thing I need to order is retractable running boards since my wife is 5'. My diesel Ram Megacab came with factory AMP powersteps. I do not plan on doing serious rockcrawling with this vehicle however, I keep looking and all the aftermarket powersteps seem to have some magnetic sticker piece that has to be adhered to the inside door frame. I think this is just looking for alignment issues or knocking it out off.
Does anyone make powersteps that somehow plug into the factory wiring and not have the magnetic door sensor?
I installed my Rockslide steps in August 2024 with the magnets and they have been perfect.
If you do not plan to Offroad , AMP make a set that uses the OBD2 plug instead of magnets. You know the deal…..
Guess I need to look again. I didnt see that option.
Hello all, I pick up my 392 Jeep monday and I the forst thing I need to order is retractable running boards since my wife is 5'. My diesel Ram Megacab came with factory AMP powersteps. I do not plan on doing serious rockcrawling with this vehicle however, I keep looking and all the aftermarket powersteps seem to have some magnetic sticker piece that has to be adhered to the inside door frame. I think this is just looking for alignment issues or knocking it out off.
Yes as stated magnets are required but they are double sided taped in place . I don’t even notice them . They are not the least bit in the way .
Never an issue. RSE is nice we like ours . The only thing is I would like to have seen the brackets be a little more beefy . 1/4 inch would be nice . If i were to guess I’d say the four brackets on each side are 3/32 steel then powder coated for 1/8 over all look. I replaced the aluminum rivets with 1/4 20 bolts and added 5 more bolts on the bottom no drilling holes already there. This is for the 1/4 inch skid .
I have the RSE steps. They are more than capable of supporting the weight of the vehicle, especially if you get the overlay skid add ons.
One negative I have is they occasionally droop and I have to pull the fuse to retrain them on the fully closed position.
The magnets and reed switches are completely unobtrusive.
All in all, I like them more than the amp, but only because I intend to drag them on rocks. The amps would be torn off under those conditions. If it was a pavement princess I would absolutely consider the amp steps.
This will not be a pavement princess but I do not see myself doing serious rock crawling.
When I installed my RSE steps I was a little taken back by the magnet and after having the one on the passenger side slip down I simply marked its position with a sharpie, grabbed a tube of black silicone and put a dab on the back of the magnet and put it where it needed to be.
It won't come off again unless I choose to pry it off. Simple solution to a simple problem...
