Radar Detector and Dash Cam
Just saw this thread, so sorry if I'm behind the power curve on this. I installed my Blackvue DR900X - 2CH last night. For power, I removed the access plate behind the rearview mirror on the small overhead console that houses the adaptive cruise control and collision warning system. I unplugged the connector and, using wire taps, tapped into the reddish (power) wire and black (ground) wire with the connections provided in the dashcam power cable.
The power cable that comes with the DR900X is approximately 4ft. long, so I had to shorten it up a bit. After I connected and tested, I put everything back together and it works like a champ. For the rear camera, I debated putting it on the rear glass, but ultimately decided to mount it on the rear "roll" bar. The cabling for that camera was simply routed along the roofline and under the removable panels.
Here's a couple of pics. I had not routed the rear camera cable yet. Also, when I use line taps, I typically wrap with electrical tape...just in case our resident electricians have a cow...:cool:.
View attachment 3328View attachment 3329
Thanks Rugbyref! Good stuff!
Stopped at the dealer today...I am attaching the mirror diagram for those of you wanting to use a Mirror Tap to connect a radar detector and or a dash cam. Black is Ground, Gray/Pink wire is hot.
Thanks Porscheman!
Has anyone determined that Blendmount is now making a amount for the 392 for an escort 360 Max C or 360 Redline C? The Blendmouint Website Vehicle Fit Tool is very confusing and inconclusive.
Thank you for thoughts!
A few months ago I contacted them and was told they tried to make a mount but due to the configuration on the mirror neck, they couldn't make one. I took a piece of a clear plastic ring from an old flagpole, cut a slit in it and put it on the mirror neck. Took an old Blendmount off one of my Porsches and fitted it around the plastic. Works great! I initially tried to use black electrical tape to build up the neck but that didn't last very long, was to pliable.
Just following up on this post. Is anyone currently using a BlendMount radar detector mount in their jeep 392 to mount an escort redline 360 C? If so, I would appreciate it if you could provide an exact model number so that I may order the mount. If you're using a different very clean, professional – looking mount, please provide the details.
Thank you again for your efforts!
Has anybody figured out a mount for the Escort Redline 360c yet?
Thanks!
This and your pics were very helpful. Got my V1G2 wired up solely based on your posts. Thanks man!
Looking a purchasing Valentine V1-G2 . Web owners manual warns of possible lazar detection issues (false alarms) from using adaptive cruise control? Wouldn't want to turn OFF lazar detection.
Anyone had issues?
Has anyone tried using velcro to mount radar detector onto flat area behind mirror?
Under sensors for adaptive cruise control and accident detection.
Anyone had issues?
None at all. Mounted my V1G2 to the mirror stem in between the mirror and ACC housing. Used this mount and tapped into power indicated in the wiring diagram at the beginning of this thread.
Radar Mount Mirror Mount Bracket + Mirror Wire Power Cord - Valentine V1 Radar Detector https://www.amazon.com/dp/B00JG5RHLK/?tag=jeep392-20
Reactions: RJP
Reactions: RJP
I was unable to use my BlendMount/V1G2 on my last vehicle and now my 392. I improvised by removing the clip from the visor mount and attached it to the ACC housing via a skinny bolt and spacer. There is plenty of clearance for the nut and clears the bottom of the mirror. Now I just need to tap into the mirror power.
Has anyone used a Dongar power adapter or a FitDVR to tap into the rearview mirror to power a dashcam? If so, could you share the specific model or the number of pins on the adapter you used?
Thanks!
Escort Redline, I like the placement and the cord is tucked away decently.
Bringing this thread back up to see if anyone else has figured out other mounting solutions for around the neck of rear view mirror mount?
So.... I hacked my stock setup pretty early on, because the mirror hangs so low, that it obstructed my vision. In looking for a way to get it higher, I popped the mirror head off the mount, added a Ram ball mount to the mirror head, and added a Ram mounting arm between the two (I also had to extend the wires a bit). I posted details on here somewhere back then. This is what it looks like now. I've been running this setup for almost three years in both 392s.
But, as my build progresses, I can see less and less out the back window, and I wanted to add a dashcam to back me up should anything stupid happen on the road. So I recently ordered a three camera system from Wolfbox, which offered a Jeep specific mount as an accessory. It replaces the stem sticking down out of the box, with a ball mount for the Wolfbox Mirror/screen. I took the mounting plate, and added a Ram ball to it so that it will be a direct swap for me.
Here's what the Wolfbox stuff looks like:
The ball mount on the stem has 4 small screws that will let you take it apart, and remove the Wolfbox mount, leaving you with a direct bolt-in stem with a ball on it. From there you have endless options to mount whatever you want.
Note that the OEM ball is a non-standard size and required some grinding on the doggone clamp to make it work. Also, these mounts come in different size balls, so getting everything to mount up might require some custom links and such. Bullet Point has a section, and I've used several of them for mounting other stuff, including a bunch of connectors and adapters for different size balls. Link: https://www.bulletpointmountingsolutions.com/collections/connectors-and-adapters
Here's the link to the bracket: https://wolfbox.com/products/wolfbo...-g900-g850-g840s-g840h?variant=48235280498977
I hope that helps someone.
View attachment 47881View attachment 47882
Won't the camera on the Wolfbox mirror be blocked by the the box on the windshield. Or are you going to just use the camera that mounts on the bumper or wherever as the front 'dash cam'?
